> said i could not lower my car?, 1.4" drop
post Jul 4, 2005 - 12:28 AM
ArizonaRed
Joined Sep 17, '03
From Tampa FL
i have 17" rims on my car and the body shop said i could not lower my car unless i wanted to decrease my turn radius. they said this is because of the rims & tires i have. is this true? i was wanting to lower it the 1.4&1.3" kit.
-97 Celica ST
-2001 Celica GTS dk blue mica 100hp per litre
(GOT LIFT?)
post Jul 4, 2005 - 12:43 AM
i call BS
i have 18s on my car with like 2.5" or more drop and i can turn just fine
post Jul 4, 2005 - 2:05 AM
Currently Online
What size are your tires?
post Jul 4, 2005 - 2:15 AM
macavely
Joined Nov 4, '02
i depends on the tire and wheel hieght and witdh .. but with 17s you shouldn't have problem ..
post Jul 4, 2005 - 12:17 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
If you've correctly adjusted the size of your tires down as your wheel size went up, larger wheels shouldn't matter (e.g. 185/65R14 is the same 23.5" diametre as 205/40R17). Wider tires, on the other hand, can be a problem.
225 is the max I've seen run with a drop on the fronts -- most people I know use 215 on even 18s.
post Jul 4, 2005 - 12:47 PM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
i have 17's on my car and its lowered 1.5inch's and its fine
post Jul 4, 2005 - 10:12 PM
ArizonaRed
Joined Sep 17, '03
From Tampa FL
look at my pic, theyre smaller tires. its the same height as stock. guess that answered my question.
-97 Celica ST
(GOT LIFT?)
post Jul 5, 2005 - 7:16 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
you might just have to roll the fenders..
post Jul 8, 2005 - 7:24 PM
slipgun
Joined Jun 2, '03
From Annandale VA
you should be absolutly fine, exept you may want a new shop.
post Jul 8, 2005 - 8:03 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
isn't rolling fenders what you do to fit bigger tires.
post Jul 8, 2005 - 8:37 PM
tim86
Joined Oct 31, '03
From Orlando, Florida
i have 17's as well with no rubbing or decreased turn radius and its dropped more than 1.5 for sure... youll be fine
post Jul 9, 2005 - 12:24 AM
MonsterBOX
Joined Jan 8, '05
From Alabama
dont worry at all...even if u have big ass tires or something crazy it cant be that bad we already have pretty damn good radius
post Jul 10, 2005 - 9:53 PM
Junior
Joined May 5, '03
From Toronto
17's will be no problem as long as you have the proper offset.
Lo-Fi Version Time is now: April 22nd, 2025 - 11:23 PM
