> 3sgte water pump(s)?, Are there any options?
post Jul 8, 2005 - 12:39 AM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
Google is giving me nothing useful, i may be searching the wrong things.
i know OEM quality is good, but i'm curious if there's a such thing as "performance water pumps" for the 3s-gte like Mopar sells.
if so could someone point me in the right direction?
if not, where's the best place to get a deal on OEM?
post Jul 8, 2005 - 12:54 AM
Consynx
Joined Dec 25, '02
please go easy on me, i can realize that this may be a very stupid question and no such thing exists because they all do a simple task...but iunno
post Jul 8, 2005 - 5:58 PM
Consynx
Joined Dec 25, '02
saw a Greddy Timing Belt...for some heat resistance you gotta add $200 tongue.gif
post Jul 8, 2005 - 10:55 PM
ems3s
Joined Jun 17, '05
From Melbourne, Australia
I originally was going to use a electric water pump for my WTA i/C but i ditched the cooler and used a FMIC. I then decided to use the pump for its proper use(Engine). The Davies, Craig electric water pump, pumps 80l/min and can run constant or switched by a thermo sensor. It has the correct 32mm fittings to fit the original lines. All you have to do is remove the impeller fins of the original pump and the thernostat. It works great, at the moment i'm playing with the trigger of my EMS 8860 ecu to control the temp precisely.
This pump can give you a few extra horses cos it removes the resistance from the timing belt.
You probably won't have a clue what i'm talking about or what it looks like but try this mob in Oz that have dealers in the US
http://www.daviescraig.com.au
Lo-Fi Version Time is now: November 24th, 2024 - 6:13 PM
