> NA 2.2 Exhaust size, What's the best size?
What's the best size exhaust?
Total Votes: 38
Guests cannot vote
post Jul 21, 2005 - 4:43 AM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
I know the topic has been discussed a few times, but I'm wanting to put it to a pole. I'd like to get a good gain out of my new headers, and I think a nice sized exhaust would help that. It's a 2.2 n/a with little mods. I'm thinking 2.25 will give me the best gains, but I'm not positive enough to just do it. Thanks for the input.
Live Free, Be Happy
post Jul 21, 2005 - 7:03 AM
CelicaZR
Joined Mar 25, '05
From Sydney, Australia
I was told 2.25 is the best size for my celica which is the 2.2L.
6GC 4 Life Baby!!!
post Jul 21, 2005 - 7:04 AM
CelicaZR
Joined Mar 25, '05
sorry double post.
Mod please delete
This post has been edited by CelicaZR: Jul 21, 2005 - 7:06 AM
6GC 4 Life Baby!!!
post Jul 21, 2005 - 7:57 AM
rlan214
Joined Dec 27, '02
From Sleep in Warren chill in clinton twp, works/school in detroit
greddy sp is about 60 mm smile.gif thats for gt
post Jul 21, 2005 - 3:23 PM
darksecret
Joined Mar 9, '05
From Charlotte
I wouldn't go higher 2.25, any larger would be a waste of metal and add useless weight.
post Jul 21, 2005 - 3:59 PM
mark_426
Joined Jan 30, '05
From Greencastle, PA
Umm, i thought stock was 2.25?
I'd say no greater than 2.75 - 2 3/4
.. maybe not. 60 millimeters = 2.36 in
This post has been edited by mark_426: Jul 21, 2005 - 3:59 PM
post Jul 21, 2005 - 4:24 PM
SlowCelica94
Joined Sep 28, '03
From Bloomington, IN
2.25 is idel for 5s's. Make sure you buy a resisnator w/ 2.25 in/outlets if you plan on still running one. Dynomax has a nice selection. Also, I recommand a muffler with some baffles in it insted of a striaght through muffler.
92 Civic hatch B16 - Sold
10th anniv RX-7 - RIP
post Jul 21, 2005 - 6:00 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
3"
MUST HAVE 3...it's a do or die thing
post Jul 21, 2005 - 6:39 PM
3in is only good for a turbo car. for a normal 5sfe you would want 2.25-2.50 at most. backpressure is a good thing on an NA car...but a bad thing on a turbo car.
post Jul 21, 2005 - 7:03 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Cars do not need backpressure -- it's a myth.
Big pipes have lower initial backpressure, but quickly create turbulence (a form of backpressure) because they let the gas expand, cool and slow down. Exhaust therefore cannot exit the engine as quickly and efficiently, and energy that should be going to turning the crank is instead being used to push exhaust gases out.
Backpressure is an inevitable consequence of not having a variable exhaust size. The harder the engine is working, the more exhaust it needs to get rid of, and the ideal situation would be for the exhaust pipes to grow as the engine pumps out more fumes.
Since we don't have that technology, what we do is pick a compromise size. It's not as efficient at low revs as a small pipe, because the exhaust gases have room to expand, cool and slowdown, reducing the scavenging effect and forcing the engine to expend energy on moving what is now heavier gas. At high revs it's not as efficient as a larger pipe, because the gas bottlenecks. Either way, you get backpressure. The compromise aims to minimize that backpressure over the band, and preferably have the most efficient exhaust extraction (high velocity, lowest backpressure) at the RPM point where the engine spends the most time.
Really big pipes are good only if you're producing enough exhaust to be efficiently using them. This is where FI and NO2 come in, since they effectively simulate greater displacement and therefore a bigger engine.
post Jul 22, 2005 - 1:15 AM
urbandork
Joined Jul 16, '04
From Los Angeles
perhaps 2.5 with a baffled magnaflow 2.25 w/ straight through. with a what ever else u want to run?
This post has been edited by urbandork: Jul 22, 2005 - 1:16 AM
post Jul 23, 2005 - 9:33 AM
1995st204
Joined May 25, '04
From Columbus Ga
Because i was planning on turboing my 5sfe i went ahead and did a 2.5 in exhaust. It helped me out on the top end but i lost some of the bottom end. It also made my car really loud. I would stick with 2.25.
post Jul 24, 2005 - 9:28 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Why would you mismatch your pipe size and muffler size?
Lo-Fi Version Time is now: November 27th, 2024 - 7:20 PM
