> Ok, what can i do to my 5sfe??, engine w/o the swap??
post Dec 10, 2002 - 10:23 PM
Phat_99CeliGT
Joined Aug 30, '02
From Ohio
Well????
Lets hear them.
So far im at:
UR pulley
Upgraded plugs and wires
Header
Im looking to add some hp, but not MAD hp.
Ya guys think im good with what i got??
Jared Harwell
post Dec 10, 2002 - 11:00 PM
Do you have full exhaust? If not, then you could get larger piping and a universal muffler, or you could get a full cat-back if you wanted. Also, you could get or make a cold air intake for your car and do some stuff with your ignition.
post Dec 11, 2002 - 12:19 AM
Phat_99CeliGT
Joined Aug 30, '02
From Ohio
Ok, here is my mod list so far:
2.5" exhaust from flex back
Homemade CAI 3"
and thats it.
Jared Harwell
post Dec 11, 2002 - 12:51 AM
Mynzeyes
From Franklin/Nashville, TN
dude, check some places about maybe some injectors, a fuel pump, maybe a fuel pressure regulator... then get a S-AFC to manage all that, so you don't run too rich/lean... i think Venom makes all that stuff for our cars...um...you could also upgrade the ignition system, but don't expect too much outta that til you have other mods...you get better MPG and some of the lag is takin out when accelerating from a roll...um...i'd go w/ the header...and pulley...wires and plugs DEFINATELY if you upgrade the ignition system...um...that'd basically be a lotta the stuff you could do to an engine w/o gettin inside of it...just upgrade all the fuel/air delievery, then also the releasing of all that through the exhaust, that should free up the engine a nice amount. hope that helps man.
-John-
AIM==Mynzeyes
post Dec 11, 2002 - 1:20 AM
I thought you already had all of the stuff in that first post. wink.gif I've heard good things about the Unorthodox underdrive pulley, and I've also heard that the header doesn't provide too big of a performance boost, but sounds better and adds a little bit of power.
post Dec 11, 2002 - 3:22 AM
3TST
Joined Sep 27, '02
From UK
Judging by the orginal post you probably don't want to do this....but I'll mention it anyway.
$2500 gets you a complete 5SFE Turbo Kit.
(see http://www.poweredbytoyota.com/ssfeturbo.html)
Otherwise, I agree with everything that has previously be said.
Here's a list:
Ignition upgrade = iridium plugs, wires, coil, ign. module.
Fuel component upgrade = Venom Elect. Fuel Pump, Venom Fuel Injectors, an Adjustable Fuel Pressure Regulator.
Air Intake = RAM or Cold Air Intake.
Exhaust upgrade = Header, Greddy SP cat-back system.
Enigine - Unorthodox underdrive crank pulley.
The 6GC Parts Database is extremely useful to find what's available and manuf..
post Dec 11, 2002 - 9:14 AM
all4sho94st
Joined Aug 30, '02
From NoVa
post Dec 11, 2002 - 12:11 PM
trdcelica99
Joined Oct 21, '02
From florida
don't forget the tranny, you can get a lot of torque out of a racing clutch, and short shifter
post Dec 11, 2002 - 4:15 PM
Phat_99CeliGT
Joined Aug 30, '02
From Ohio
I knew i forgot something.
I have a short shifter. homemade.
what is a good clutch and about how much we looking at here??
Jared Harwell
post Dec 14, 2002 - 5:45 PM
1bwilson
Joined Aug 30, '02
From Maryland
ACT clutch. Looking around 300 or so. If you are going to up the fuel I have 2 Venom python high flow injuctors that i will sell you for 50.
-Bryan-
Member of Team 5sfTe
post Dec 14, 2002 - 8:47 PM
QUOTE (Phat_99CeliGT @ Dec 11 2002, 02:15 PM)
post Dec 15, 2002 - 6:47 PM
Joined --
i can get the ACT clutch for around 200 bills......anybody need 1.......hit me up iexquizitcelica@aol.com.
post Dec 16, 2002 - 1:09 AM
Phat_99CeliGT
Joined Aug 30, '02
From Ohio
Is that ACT deal only good for so long, or can u get them whenever??
Jared Harwell
post Dec 17, 2002 - 12:43 AM
1bwilson
Joined Aug 30, '02
From Maryland
LSD would be a good investment also.
-Bryan-
Lo-Fi Version Time is now: February 17th, 2025 - 9:32 AM
