fuel pump harness |
fuel pump harness |
Aug 24, 2005 - 3:21 PM |
Enthusiast Joined Oct 10, '04 From New Jersey Currently Offline Reputation: 0 (0%) |
i just got my new fuel pump and have to splice the wires and was just wondering which is the neg. and pos. coming off the stock fuel pump. theirs a red wire and a blue wire. iam guessing the red is positive and the blue is negitive but i just wanna make sure. thanks
Aug 24, 2005 - 3:24 PM |
I thought the fuel pump positive wire was black with a blue stripe. I know that if you cut that wire the car won't start.
Edit: Toyota electrical diagrams say that there's a blue wire with a black stripe that's positive, and a white wire with a black stripe that's ground. This post has been edited by Coomer: Aug 24, 2005 - 3:27 PM -------------------- New Toyota project coming soon...
Yep. (to the blue being ground.)
This post has been edited by Supersprynt: Aug 24, 2005 - 3:24 PM -------------------- |
Aug 24, 2005 - 3:25 PM |
but it says to hook up the fuel pump u have to splice the wires togeather
Aug 24, 2005 - 3:49 PM |
what kind of pump did you get?
Aug 24, 2005 - 4:00 PM |
QUOTE(StreetRacing10PSI @ Aug 24, 2005 - 4:25 PM) but it says to hook up the fuel pump u have to splice the wires togeather [right][snapback]327685[/snapback][/right] the fuel pump should come with a harness. The harness on the stock pump wont fit into the plug on the new pump. So you cut the plug off the old assembly, and attach the new harness. -------------------- |
Aug 24, 2005 - 4:15 PM |
QUOTE(Supersprynt @ Aug 24, 2005 - 2:00 PM) QUOTE(StreetRacing10PSI @ Aug 24, 2005 - 4:25 PM) but it says to hook up the fuel pump u have to splice the wires togeather [right][snapback]327685[/snapback][/right] the fuel pump should come with a harness. The harness on the stock pump wont fit into the plug on the new pump. So you cut the plug off the old assembly, and attach the new harness. [right][snapback]327692[/snapback][/right] hit the nail on the head -------------------- yea your 3sgte is cool but ill stick to my 7agte
Aug 24, 2005 - 11:12 PM |
i got the wallbro 255
Aug 25, 2005 - 9:46 AM |
QUOTE(StreetRacing10PSI @ Aug 24, 2005 - 9:12 PM) i got the wallbro 255 [right][snapback]327829[/snapback][/right] thats what i have just cut your old oem harness and solder on the new one you should have direction in with your pump -------------------- yea your 3sgte is cool but ill stick to my 7agte
Aug 25, 2005 - 5:43 PM |
i just spliced the wires, and it works fine, only thing is is that i dont have my back seats in so its sorta loud but w/e thats what the kicker subs are for
Aug 25, 2005 - 5:47 PM |
QUOTE(StreetRacing10PSI @ Aug 25, 2005 - 3:43 PM) i just spliced the wires, and it works fine, only thing is is that i dont have my back seats in so its sorta loud but w/e thats what the kicker subs are for [right][snapback]328010[/snapback][/right] yeah walbro pumps are on the load side -------------------- yea your 3sgte is cool but ill stick to my 7agte
Lo-Fi Version | Time is now: November 23rd, 2024 - 12:24 AM |
