> I Don't get it anymore?, Engine seems to work somewhat now.....
post Aug 26, 2005 - 12:19 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
Ok, so back to my 4age ST. I fried the ECU a while back and the car had terrible F/A mixture. Today, I got a new Distrubtor cap and installed it in the engine along with the rotor. The old one had a crack on it where the spark wire went to CYL 2 or 3 not sure anymore.
Anways So I hook up the Fried ECU to test the new cap and rotor and WHAM! The engine starts working ok again with good A/F Mix ( 8% rich). WTF is with this? The engine seems to work when it wants too and doesn't when it doesn't feel like it.
I wonder if my engine is cursed? (Like some Japanses guy died drifting in it)
Oh Yeah, FYI an engine will not start if the ECU was just plugged in and hasn't recevied the chance to 'boot up'. (I feel like an idiot)
post Aug 27, 2005 - 12:36 PM
Rjb23
Joined Feb 8, '04
From KY
Probably the ECU reset itself, and also the crack in the distributor might have had something to do with it.
As in the 2 cylinders could have not been getting strong enough spark to burn the fuel causing it to run rich.
This post has been edited by Rjb23: Aug 27, 2005 - 12:38 PM
post Aug 27, 2005 - 2:32 PM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
what are u measureing you A/F with to make these claims?
any problems in your ignition system will cause the car not to run or if it could run, it will run like ****.
Lo-Fi Version Time is now: November 30th, 2024 - 11:08 AM
