S2000 antenna |
S2000 antenna |
Sep 1, 2005 - 10:10 AM |
Enthusiast Joined Nov 12, '02 From Baltimore, MD Currently Offline Reputation: 1 (100%) |
Hey all just giving some pics of my new S2000 antenna that I put on today. I took about 20 minutes and looks pretty good!
Click on the pics to see bigger versions. -------------------- |
Sep 1, 2005 - 10:24 AM |
Enthusiast Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) |
Nice. Still deciding if i should remove the antenna completly (paintjob within a month) or getting the S2000 one!
-------------------- JDM Powerplant installed, BPU coming very soon!
Sep 1, 2005 - 10:27 AM |
Enthusiast Joined Jun 30, '03 From O-town, FL Currently Offline Reputation: 0 (0%) |
Lookin good. Just like mine. Did you cut stuff up or not? I used seventh gen peices and mated it to fit with my car. Easiest way if you ask me, you gotta spend a little more but you don't have to cut anything or risk damaging the car.
Sep 1, 2005 - 11:02 AM |
QUOTE(Akimbo @ Sep 1, 2005 - 10:27 AM) Lookin good. Just like mine. Did you cut stuff up or not? I used seventh gen peices and mated it to fit with my car. Easiest way if you ask me, you gotta spend a little more but you don't have to cut anything or risk damaging the car. [right][snapback]330115[/snapback][/right] Yeah I cut the whole antenna off at the base. It took the most time trying to get the pieces of antenna apart but after that I just followed the how to. -------------------- |
Sep 1, 2005 - 11:08 AM |
Enthusiast Joined Jan 28, '05 From Redondo Beach, CA Currently Offline Reputation: 86 (100%) |
i asked toyota how much for the 7th gen pieces and they are a rip off! $70 for the base, 12 for the plastic piece, and 17 for the mast.
Sep 1, 2005 - 12:44 PM |
i just got on team celica and someone was parting out a gt
Sep 1, 2005 - 1:02 PM |
Enthusiast Joined Oct 4, '02 Currently Offline Reputation: 0 (0%) |
For people who don't want to pay a lot of money for an S2000 conversion:
I just installed an antenna from locustom.com. It's called the 'Shark Attack 2' and is basically an S2000 antenna with an angled base. It was really easy to install. Just plugged in the antenna plug and spliced the power wire to the grey wire on the OEM power antenna harness. The amp is integrated into the base. My OEM powered antenna was completely removed. There was no need to keep/modify anything. It costs $35. They have other conversions on their site also. So far the FM reception is the same and the AM reception is good, but crappy when in weak signal areas. |
Sep 7, 2005 - 10:17 PM |
Enthusiast Joined Feb 8, '05 From Cambridge, ON, Canada Currently Offline Reputation: 1 (100%) |
QUOTE(LewFX @ Sep 1, 2005 - 11:08 AM) i asked toyota how much for the 7th gen pieces and they are a rip off! $70 for the base, 12 for the plastic piece, and 17 for the mast. [right][snapback]330135[/snapback][/right] this is what i did, just got the 7th gen peices but my dad works for the toyota plant up here, so i got some nice discounts -------------------- lissa | 1997 Celica Convertible
*My other ride is your boyfriend* ;) |
Sep 7, 2005 - 10:19 PM |
Enthusiast Joined Aug 17, '03 From Bloomington, Indiana Currently Offline Reputation: 62 (98%) |
does everyone here have constant stick up antenna's or does ne one have a power one like mine.
Sep 8, 2005 - 6:28 AM |
I used to have a power one before I put the s2000 one on. I think all 6gcs come with power antennas.
Sep 8, 2005 - 3:02 PM |
i have my s2000 antenna waiting for me, i dare not cut the power antenna tho.
Sep 9, 2005 - 11:32 PM |
Enthusiast Joined May 6, '05 From PA Currently Offline Reputation: 4 (100%) |
QUOTE(bojangles_8686 @ Sep 8, 2005 - 7:28 AM) I used to have a power one before I put the s2000 one on. I think all 6gcs come with power antennas. [right][snapback]332049[/snapback][/right] Nope, I never had one, the was no wiring or anything for it. I just ran my own wires to my HU and put in a bypass switch. -------------------- |
Sep 10, 2005 - 12:26 AM |
Enthusiast Joined Oct 13, '03 From Dandridge, Tennessee Currently Offline Reputation: 0 (0%) |
I got my s2000 antenna for free off of a Honda Element in a junk yard. I love the look.
-Brandon -------------------- |
Sep 28, 2005 - 7:42 PM |
bump:) guys what base did u use? Mine is crfap so do I need just a new one or some different base?
Sep 29, 2005 - 9:28 AM |
Enthusiast Joined Sep 29, '02 From Sterling Heights, Michigan Currently Offline Reputation: 0 (0%) |
QUOTE(dustin15brown @ Sep 28, 2005 - 8:42 PM) bump:) guys what base did u use? Mine is crfap so do I need just a new one or some different base? [right][snapback]339239[/snapback][/right] What's wrong with you're base? The 6th gen base and the 7th gen base are the same. Just get a new one. |
Sep 29, 2005 - 3:02 PM |
Enthusiast Joined Feb 9, '03 From Sioux falls, South Dakota Currently Offline Reputation: 1 (100%) |
i worked for a dealership and i got the full S2000 base, mast, all the plastic, and actual antenna electronic compenets. it cost me 60 but it allscrews right in and works perfectly.
-Aaron- -------------------- |
Oct 28, 2005 - 5:51 PM |
Enthusiast Joined May 16, '05 From Toronto, Ontario Currently Offline Reputation: 8 (100%) |
i read the how to for this... but er... if we have a power antenna.. don't we need to replace the thing inside the trunk? the sub-antenna bracket or wutever thing? or we don't ned it...
actually.. from the how to of the other site, the sub antenna assembly is PN: 86309-20300... is that what we have already? This post has been edited by elvasoshexai: Oct 28, 2005 - 5:55 PM -------------------- |
Lo-Fi Version | Time is now: January 11th, 2025 - 1:15 AM |
