> Taking out air conditioner...
post Sep 2, 2005 - 3:56 PM
Vibe
Joined Dec 7, '04
From Antioch, Norcal
Hi I was thinking about cutting the A/c belt to free up some power, are there any draw backs from this? Has anyone done this before? Any tips, pros cons? Thanks in advance.
post Sep 2, 2005 - 4:18 PM
Doesn't the power steering pump run on the same belt?
post Sep 2, 2005 - 4:35 PM
QUOTE(Coomer @ Sep 2, 2005 - 4:18 PM)
[right][snapback]330608[/snapback][/right]
nope..
the altinator does tho... you would need to get a new shorter belt to make this work. i really dont think you would gain much power from it, since the ac only really robs you of power when its on and running.
post Sep 2, 2005 - 5:34 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Now if he removed the actual AC units to save weight....
post Sep 2, 2005 - 6:10 PM
blu94gt
Joined Mar 23, '05
From Kansas City
QUOTE(lagos @ Sep 2, 2005 - 4:35 PM)
nope..
[right][snapback]330620[/snapback][/right]
Yeah, unless you actually remove the AC you're not going to gain anything. Yes its on its own independent belt, but unless the AC is on it isn't using any power. You would be better off to remove all of the AC assembly to save weight, and then remove the power steering to free up some power
1999 Celica GT
Lo-Fi Version Time is now: February 17th, 2025 - 12:11 AM
