brake rotor removal |
Sep 6, 2005 - 2:14 AM |
Enthusiast Joined Dec 13, '03 From Alabama Currently Offline Reputation: 1 (100%) |
I'm trying to remove my brake rotors on the front to have them turned. I looked at the big green book on celicatech and it says with the calipers off it will just slide off. but when i try to remove it it won't budge. It seems as though the spindle nut?? is holding the rotor on. Do you have to take that bolt off or are my rotors just really rusted on there?
Sep 6, 2005 - 7:10 AM |
thyere prolly just rusty.
there are 2 smaller threaded holes in the rotor, that you can thread a bolt thru to push off the rotor. good luck! -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Sep 6, 2005 - 9:36 AM |
Enthusiast Joined Nov 4, '02 From Hecho en la Republica Dominicana/Living in NJ Currently Offline Reputation: 0 (0%) |
you can also try tapping it with a rubber hammer..
Sep 6, 2005 - 10:37 AM |
Enthusiast Joined Jan 17, '04 From Illinois Currently Offline Reputation: 0 (0%) |
QUOTE(Justin @ Sep 6, 2005 - 2:14 AM) I'm trying to remove my brake rotors on the front to have them turned. I looked at the big green book on celicatech and it says with the calipers off it will just slide off. but when i try to remove it it won't budge. It seems as though the spindle nut?? is holding the rotor on. Do you have to take that bolt off or are my rotors just really rusted on there? [right][snapback]331382[/snapback][/right] I had the same problem. Do what Manny says. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Sep 6, 2005 - 11:18 AM |
Enthusiast Joined Oct 10, '03 From Wichita, KS Currently Offline Reputation: 5 (100%) |
Just give it a swift kick. It'll come right off.
-------------------- Project ST204.5 99.88946% complete... |
Sep 6, 2005 - 11:03 PM |
Enthusiast Joined Mar 3, '05 From Richmond, B.C. Currently Offline Reputation: 0 (0%) |
And in a bit of convenience, the bolts to use for backing off the rotor are the ones used to mount the caliper to the bracket.
Sep 7, 2005 - 8:47 AM |
Enthusiast Joined Jun 14, '05 From colorado Currently Offline Reputation: 0 (0%) |
QUOTE(Galcobar @ Sep 6, 2005 - 11:03 PM) And in a bit of convenience, the bolts to use for backing off the rotor are the ones used to mount the caliper to the bracket. [right][snapback]331580[/snapback][/right] the holes he is talking about are on the front of the rotor inbetween two studs, i think they are 8mm x 1.25 -------------------- |
Sep 26, 2005 - 12:04 AM |
thanks for the help ill try that sometime this week. they are def really rusted on there
Lo-Fi Version | Time is now: December 4th, 2024 - 1:18 PM |
