![]() Enthusiast ![]() Joined Mar 11, '03 From Springfield, Ohio Currently Offline Reputation: 0 (0%) ![]() |
Is there a way to check the Check Engine Light codes on these cars without taking it to a dealership and paying them like 80 dollars to just get the code. i know that on most hondas there is a way that you can check it yourself without paying someone to do it. Some one...........PLEASE HELP!!!
thanks -jeremy- -------------------- |
by the way it is a 2.2 5sfe GT
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 29, '03 Currently Offline Reputation: 0 (0%) ![]() |
![]() Enthusiast ![]() Joined Oct 19, '04 From orlando Currently Offline Reputation: 0 (0%) ![]() |
take your car to autozone or discount auto parts is free and they'll give you a code report
Enthusiast ![]() ![]() ![]() Joined Jul 27, '04 From phoenix az Currently Offline Reputation: 0 (0%) ![]() |
go to autozone if you have one by you they check it for you for free.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 19, '04 From Scottsdale, Az Currently Offline Reputation: 2 (100%) ![]() |
QUOTE(trdevelopment @ Sep 19, 2005 - 7:38 PM) go to autozone if you have one by you they check it for you for free. [right][snapback]336123[/snapback][/right] Hes right, they will tell u what u need. FOR FREE |
Enthusiast ![]() ![]() Joined Dec 8, '04 Currently Offline Reputation: 0 (0%) ![]() |
Not every AutoZone will check it for you for free.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 4, '02 From Hecho en la Republica Dominicana/Living in NJ Currently Offline Reputation: 0 (0%) ![]() |
check the how to s ... or you can just connect the TE1 and E1 with a papyer clip since you have a 95... (in the little box on driver side of the engine bay .. above the main fuse box) ... then turn your key to the ACC position and read the flashes...
it is really weird, i tried that and nothing happened. so i started the car and then drove it down the road and then the light came one again. so i pulled back in the drive way and tried to pass the code again and as soon as i shut the car off and turned it back on, the light was out and when i set the jumper, there was no code. does this sound really weird to any one else???
i was thinking, does this sound like a o2 sensor problem?
Enthusiast ![]() ![]() Joined Sep 12, '05 From Who says you can't circle race a celica? Currently Offline Reputation: 5 (100%) ![]() |
Might be a soft code but I doubt it. make sure the key is on engine off when you jump the 2 test points.
-------------------- 94 GT Liftback
86 GTS Coupe (Racecar) #99 Crew Chief |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jul 19, '04 From Los Angeles, CA Currently Offline Reputation: 2 (100%) ![]() |
i tryed the t1 te1 thing or whatever and it didnt work for me either. my guess (could be wrong) is that its different for obd II cars, but im pretty sure the 95 gt is obd I, so i donno. i brought it to an auto place, they said o2 sensors for me, and i replaced both of them and it fixed the code.
thanks guys, i will do that after work today.
Lo-Fi Version | Time is now: February 19th, 2025 - 3:21 AM |
