map sensor??????, boost sensor swap |
Sep 20, 2005 - 11:35 PM |
Enthusiast Joined May 24, '03 From Andrews TX Currently Offline Reputation: 1 (100%) |
I don't know if anyone has asked this yet...
But can I use a 2-bar 3SGTE map sensor on my 7AFTE, I have heard of HONDA guys that I know of using 1.2-2.0bar map sensors off of other vehicles on thier swapped cars so they don't keep damaging MAP sensors and get better readings, so can we do this as well?? I have heard that my SAFC-IIv2 can transfer these signal to be able to work with vehicles, and I don't mind changing clips if that has to be done, or radd seperate power & ground wires for the sensor??? -------------------- If anyone is missing NASCAR and it's not on Speed Channel, take a fistful of Skittles, throw them in the toilet and hit the flush handle. Instant NASCAR!!!
Sep 20, 2005 - 11:39 PM |
Enthusiast Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
QUOTE(dans_st @ Sep 21, 2005 - 4:35 AM) I don't know if anyone has asked this yet... But can I use a 2-bar 3SGTE map sensor on my 7AFTE, I have heard of HONDA guys that I know of using 1.2-2.0bar map sensors off of other vehicles on thier swapped cars so they don't keep damaging MAP sensors and get better readings, so can we do this as well?? I have heard that my SAFC-IIv2 can transfer these signal to be able to work with vehicles, and I don't mind changing clips if that has to be done, or radd seperate power & ground wires for the sensor??? [right][snapback]336795[/snapback][/right] If you're running an SAFC then yeah, you can do that and modify the signal as you need to. I assume you're running larger injectors as well. -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Sep 21, 2005 - 12:08 AM |
hare is basically what I am running
t28 turbocharger port on exhaust housing 3.5" downpipe HKS SSQV blow-off valve HKS 65mm BOV flange 2.5" intercooler piping Apexi SAFC-II version 2 Apexi AVC-R boost controller Turbosmart 38mm wastegate Autometer COBALT boost guage Mishimoto 31"x11"x3" intercooler Walbro 255lph fuel pump Fuel pressure regulator full port & polish on head full port on intake & throttle body ZOOM clucth INNOVATIVE LM-1 wideband O2 with datalogger fast-turbo oilfilter relocation kit Goodridge -6an fuel lines from tank Aeromotive in-line fuel filter Aeromotive boost dependant magna flow exhaust full 3.5" exhaust from manifold (all Magnaflow 3.5" mandrel bends) HKS filter MSD sportcompact ignition plus MSD custom fit 8.5mm wires MSD Blaster SS coil NX 35 SHOT w/RPM window switch I am also upgrading my turbo to a GT3076R -------------------- If anyone is missing NASCAR and it's not on Speed Channel, take a fistful of Skittles, throw them in the toilet and hit the flush handle. Instant NASCAR!!!
Sep 21, 2005 - 12:15 AM |
QUOTE(dans_st @ Sep 21, 2005 - 5:08 AM) hare is basically what I am running t28 turbocharger port on exhaust housing 3.5" downpipe HKS SSQV blow-off valve HKS 65mm BOV flange 2.5" intercooler piping Apexi SAFC-II version 2 Apexi AVC-R boost controller Turbosmart 38mm wastegate Autometer COBALT boost guage Mishimoto 31"x11"x3" intercooler Walbro 255lph fuel pump Fuel pressure regulator full port & polish on head full port on intake & throttle body ZOOM clucth INNOVATIVE LM-1 wideband O2 with datalogger fast-turbo oilfilter relocation kit Goodridge -6an fuel lines from tank Aeromotive in-line fuel filter Aeromotive boost dependant magna flow exhaust full 3.5" exhaust from manifold (all Magnaflow 3.5" mandrel bends) HKS filter MSD sportcompact ignition plus MSD custom fit 8.5mm wires MSD Blaster SS coil NX 35 SHOT w/RPM window switch I am also upgrading my turbo to a GT3076R [right][snapback]336809[/snapback][/right] Sounds like a sick setup, I have the LM-1 myself, it's a great peice. But what about injectors? -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Sep 22, 2005 - 1:54 PM |
I have the RC engineering 550cc's (part#SL9-550)
I just forgot to put them on my list of mods What year and/or car can I get that map sensor for?? I went to auto parts (a few of them) but they say MR2 didn't have MAP, and cannot look up GT-4? Also with your LM-1 did you have to buy a separate module to add on to sense RPM, or can I just hook my MSD ignition's tach output to an imput on the LM-1 without buying an extra piece?? This post has been edited by dans_st: Sep 22, 2005 - 1:58 PM -------------------- If anyone is missing NASCAR and it's not on Speed Channel, take a fistful of Skittles, throw them in the toilet and hit the flush handle. Instant NASCAR!!!
Sep 22, 2005 - 2:33 PM |
All the MK2 MR2s have a MAP sensor. Just go to www.mr2oc.com and put up a WTB thread.
You need to buy the RPM converter. -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Sep 22, 2005 - 3:18 PM |
Enthusiast Joined Oct 10, '03 From Wichita, KS Currently Offline Reputation: 5 (100%) |
They are called Turbo Pressure Sensors. That's why your parts store can't find it. The 3rd and 4th Gen 3SGTEs are the only 3SGTEs to use a MAP sensor. There is a thread at alltrac.net having to do with the AFM to MAP conversion and about how slow the response time is on this particular sensor. Since all the turbo pressure sensor does is control fuel cut due to overboost on the older 3SGTEs the theory is that it doesn't have to be as precise as the map sensors used in our newer cars. The turbo pressure sensor from the 2nd gen 3SGTE should work but probably not as well as a MAP sensor from the 3rd Gen 3SGTE or a GM 2 or 3 bar MAP sensor.
Reference: http://alltrac.net/phpBB2/viewtopic.php?t=8816 -------------------- Project ST204.5 99.88946% complete... |
Sep 22, 2005 - 3:54 PM |
I read the thread,
But, 1.is there a GM vehicle that has a MAP sensor that sense BOOST and vacuum, rather than just vacuum? 2.Does the gm MAP responds quicker and more accurately than the 3SGTE or the7AFE? 3. If YES to the previous two questions-- Can i just splice it into my wires and program the SAFC-IIv2 to make it work with my stock ECU? 4. And if I am already going with a totally different make, can I use a HONDA or DSM map sensor?, because I can get those cheap from people I know I was just trying to stay with toyota. -------------------- If anyone is missing NASCAR and it's not on Speed Channel, take a fistful of Skittles, throw them in the toilet and hit the flush handle. Instant NASCAR!!!
Sep 22, 2005 - 4:07 PM |
QUOTE(dans_st @ Sep 22, 2005 - 3:54 PM) 1.is there a GM vehicle that has a MAP sensor that sense BOOST and vacuum, rather than just vacuum? [right][snapback]337407[/snapback][/right] Yes. Example: http://cgi.ebay.com/ebaymotors/ws/eBayISAP...item=7994705880 QUOTE(dans_st @ Sep 22, 2005 - 3:54 PM) 2.Does the gm MAP responds quicker and more accurately than the 3SGTE or the7AFE? [right][snapback]337407[/snapback][/right] Yes. It is widely used by people running stand alone and piggy back systems. QUOTE(dans_st @ Sep 22, 2005 - 3:54 PM) 3. If YES to the previous two questions-- Can i just splice it into my wires and program the SAFC-IIv2 to make it work with my stock ECU? [right][snapback]337407[/snapback][/right] Yes, and the example auction I linked to even includes the connector. QUOTE(dans_st @ Sep 22, 2005 - 3:54 PM) 4. And if I am already going with a totally different make, can I use a HONDA or DSM map sensor?, because I can get those cheap from people I know I was just trying to stay with toyota. [right][snapback]337407[/snapback][/right] Sure. You're going to be tuning with the SAFC-II no matter what sensor you go with. -------------------- Project ST204.5 99.88946% complete... |
Sep 22, 2005 - 5:36 PM |
a few more questions--
Does the GM MAP sensor run off of the same voltages that my OEM sensor would other then being able to read more boost?? Basically will aside from splicing the harness, is the GM map sensor a plug-and-play? I know I can adjust the SAFC-II for it but I don't know what setting the IN and OUT on the SAFC-II should be set on if it does have to be changed? Sorry about all the questions, but I don't want to do this wrong -------------------- If anyone is missing NASCAR and it's not on Speed Channel, take a fistful of Skittles, throw them in the toilet and hit the flush handle. Instant NASCAR!!!
Sep 22, 2005 - 6:19 PM |
QUOTE(dans_st @ Sep 22, 2005 - 3:36 PM) a few more questions-- Does the GM MAP sensor run off of the same voltages that my OEM sensor would other then being able to read more boost?? Basically will aside from splicing the harness, is the GM map sensor a plug-and-play? I know I can adjust the SAFC-II for it but I don't know what setting the IN and OUT on the SAFC-II should be set on if it does have to be changed? Sorry about all the questions, but I don't want to do this wrong [right][snapback]337437[/snapback][/right] in my sds system i'm running a GM 3 bar map sensor but thats off Standalone -------------------- yea your 3sgte is cool but ill stick to my 7agte
Sep 22, 2005 - 9:45 PM |
just an fyi 3.5" is toooooooo big
but sounds like a fun plan |
Sep 23, 2005 - 8:32 AM |
QUOTE(dans_st @ Sep 22, 2005 - 5:36 PM) a few more questions-- Does the GM MAP sensor run off of the same voltages that my OEM sensor would other then being able to read more boost?? [right][snapback]337437[/snapback][/right] Yes. 0-5 Volts QUOTE(dans_st @ Sep 22, 2005 - 5:36 PM) Basically will aside from splicing the harness, is the GM map sensor a plug-and-play? [right][snapback]337437[/snapback][/right] I guess you could call it that... It obviously won't work very well without tuning it. QUOTE(dans_st @ Sep 22, 2005 - 5:36 PM) I know I can adjust the SAFC-II for it but I don't know what setting the IN and OUT on the SAFC-II should be set on if it does have to be changed? [right][snapback]337437[/snapback][/right] You'll probably need to read your manual for the answer to that one. Here is a good thread about the 3 Bar MAP and SAFC on a Honda. It's worth reading: http://www.honda-tech.com/zerothread?id=531705 -------------------- Project ST204.5 99.88946% complete... |
Lo-Fi Version | Time is now: January 11th, 2025 - 7:50 AM |
