> crankshaft timing gear
post Sep 21, 2005 - 2:05 PM
Snarfer
Joined Dec 2, '03
From Virginia
I can't figure out how to remove this gear, the chilton's and service manual just says use a puller. I have a 2 arm puller but the arms can't fit behind the rear sproket, and it seems like if it could it would bend it. Any suggestions?
post Sep 21, 2005 - 5:32 PM
gamesteristj
Joined Feb 18, '04
From Spokane Washington
I thought it showed using two screwdrivers on either end to pop it off? I will check tonight...
TJ
post Sep 21, 2005 - 5:43 PM
FallenHero
Joined Dec 26, '02
From Alabama
I used a large flat screwdriver. Wedged it in the back, and twisted, then I pried on the other side, then the other,,, you get the picture. Just put a little muscle into it.
post Sep 21, 2005 - 11:00 PM
Snarfer
Joined Dec 2, '03
From Virginia
ok cool i was just worried about messing it up, thanks.
post Sep 22, 2005 - 2:02 AM
FallenHero
Joined Dec 26, '02
From Alabama
it's cast iron... you're not going to mess it up unless you use a torch. wink.gif
post Oct 3, 2005 - 3:07 AM
ice23q
Joined Jan 16, '04
From sydney australia
you need to use two large screwdrivers ....one on ether side and pry it off easy......i cracked mine and need a new one.....
i may go for the 18% UNDERDRIVE
312whp with more to come....
Lo-Fi Version Time is now: December 3rd, 2024 - 9:39 AM
