timing and front axles?, damn brakes plus |
Oct 14, 2005 - 2:25 AM |
Enthusiast Joined Feb 8, '04 From Thornton, CO. Currently Offline Reputation: 1 (100%) |
So I took my celica in for brake work and to have both front cv shafts replaced. after the job was done i took the car out for a spin in which it worked fine for about half a day and then it started missfiring a little bit, normally when i gun it or accellerate at a good speed. its been becoming progressively worse over the past two days so i got the manager to go ahead and look it over. but my guess is, is that when the person that was doing the front drive shafts was installing everything he probably got some of the cv grease on the timing belt (when he was doing the passenger side shaft) and its been slowly spreading grease all over the belt... dunno, any thoughts tho?
-------------------- Fred
"...Armed with backbone and busted zoo gates, promising you from the bottom of my harmonica pocket - FOREVER - you will never have another lonely holiday..." |
Oct 14, 2005 - 7:13 AM |
Enthusiast Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) |
I don't think so. Timing belt is higer ups from the engine. Your driveshaft is at the transmission. So No, There shouldn't be any grease at all near the timing belt. Unless did you have him replace the belt too, if not Maybe its time you replaced your belt. It might be losing a few teeths.
Lo-Fi Version | Time is now: December 4th, 2024 - 8:08 PM |
