wheel bearing replaced new noise : ( |
Oct 14, 2005 - 7:00 PM |
Enthusiast Joined Feb 17, '04 Currently Offline Reputation: 0 (0%) |
ok so i had to replace the front wheel bearing driver side...we did it got it preessed at my firneds school shop cause midas wwas charging me 60 bucks to do it fukc that ...but now umm there is a noise when i break like it sounds like its coming from the axle but i just chanegd my axels last year wut could it be??? like with the car lfited up with the wheel on lock when i sliightly tun the wheel from side to side i hear the noise its like a crack kinda anyone know wut it could be im chekin it out more tomorrow
Oct 17, 2005 - 11:53 AM |
Enthusiast Joined Jan 28, '05 From Redondo Beach, CA Currently Offline Reputation: 86 (100%) |
maybe u got a bad axle when u got it replaced
Oct 17, 2005 - 11:57 AM |
check your lower ball joints... you kinda get that slight knocking sound when turning the wheel.
Oct 17, 2005 - 12:12 PM |
Enthusiast Joined Aug 29, '02 From ny to philly Currently Offline Reputation: 0 (0%) |
seems like the wheel bearing and ball joints have a tendency to go together. need to replace both of mine one of these weekends ..
Oct 17, 2005 - 1:52 PM |
Enthusiast Joined Aug 20, '03 From Annapolis, Md Currently Offline Reputation: 5 (100%) |
If it moves side to side, Its most likley the tierod. It it rockes when you hold the top and bottom, The bearing isnt pressed or its the ball joint. You can pull the hub out and see if it then moves, it it still moves, its the bearing. I just replaced my baring, and it is stilll screwed. I think my hub is just warn to much or somthing.
Lo-Fi Version | Time is now: November 30th, 2024 - 12:42 PM |
