> Engine Cleaning, help!
post Oct 23, 2005 - 10:05 PM
snapshotgt
Joined Oct 12, '05
From Texas
Does anyone know what i can use to clean the exterior of my engine? (w/out using crazzzzzy chemical that are really labor intensive)---specifically how to make all the metal/whole engine look new again!---that kinda stuff---thanks---
post Oct 23, 2005 - 10:13 PM
celicaGT96
Joined Aug 14, '05
From Corpus Christi Tx
Now im not the biggest fan of armorall but, what you do is buy the can that sprays foam, and just use the whole thing to spray all over your engine after you pressure wash it.
I thought it would be a problem with the sensors, but i do it all the time, and no trouble yet.
post Oct 23, 2005 - 10:22 PM
celicaST
Joined Jun 23, '05
mine was pretty dirty. me and my brother spent an hour using only detergent and armorall to get it looking like this. i wouldnt pay for any expensive chemicals. a pressure washer would also be very helpful if your engine is extremely dirty.
TheStreetzKing
Joined Jun 19, '05
yes but what percautions do u take with a pressure washer.. u cant just spray ur engine as is
post Oct 23, 2005 - 10:41 PM
Jdog1385
Joined Apr 14, '03
From Long Island, N.Y.
word. you need to seal up all electrical fittings and parts..(alternator, fuses, relay, exposed wires).
do a search on engine cleaning, you should find a lot of good info.
post Oct 25, 2005 - 3:03 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
If you know where to find your fuse boxes, alternator, spark plugs and rotor you should be fine. Pretty much everything else is relatively well-sealed. And I'm fairly sure you know where to find just about everything in your engine bay.
Fast and hard rule number one -- no pressurized water if you're not sure exactly what you're doing.
Two: No petroleum-based degreasers, they'll eat the rubber and plastics. Those types of degreasers are meant for when you're taking the engine apart and don't have to worry about non-metal bits.
Three: when using citrus-based degreasers, don't let them sit on polished or anodized aluminum as they will stain or etch the finish.
Four: elbow grease is always a safer means of cleaning than harsh chemicals or harsh tools. The Meguiar's Extra cleaner I used is safe enough it's actually meant for cleaning rubber, plastic and uphosterly as well as engines.
I wrote this detail how-to during a debate on a detailing site over how to safely clean the alternator. It was mostly to compare techniques, but I haven't found anyone who's pointed out any errors -- just the occasional preference for steam cleaning, of which I'm a little wary given it's ability to introduce moisture into electronics without you knowing.
This applies to a 1990 Toyota Celica GT with an inline 2.2L four-cylinder engine that had never previously been cleaned to my knowledge but wasn't in terrible shape. However, I only did the top half of the engine due to a persistent leak in the power steering fluid pump -- it's so slow I've been trying for years to get a bottle of stopleak into it, but power steering fluid makes an incredibly large mess with small amounts.
I should also note I have a major advantage in that the tap water in my region is collected from rain-fed rivers, meaning in a dust-free environment it dries spot-free.
Materials:
aluminum foil
shop rags
long-handled scrubbing brush
toothbrush
wire brush
Silvo metal polish
Mother's Back-to-Black
Black Magic anti-static dashboard protectant
cloth diapers
bandaids
Steps:
Ran the engine for about five minutes, let it get to the point where I could still put my hand on it.
Covered the alternator, fuse boxes, alarm computer, and sparkplugs with foil completely. Draped foil over the distributor as best I could. The stock air intake in my Celica is actually a CAI, so it didn't need covering.
Lightly rinsed the engine with a spray from the hose, then scrubbed at the more disgusting areas with the long-handled brush to loosen the grime. Rinsed again, gave the engine a quick scrub, then liberally sprayed the compartment with Extra and let it soak for 10 minutes.
From there it was elbow grease and banged-up knuckles, scrubbing at stuck-on grime with either the scrub brush or the toothbrush, depending on how tight the crevice was. Discovered how effective Extra remains, even when the brush is black. For lightly soiled areas, used a shop rag wet with Extra to wipe down, including the various hoses and plastic covers.
Lightly rinsed the compartment with the garden hose again, then used the shop rags to wipe it down, particularly concentrating on areas where water could pool. On the 5SFE, watch between the manifold and the head.
Unwrapped the covered pieces and went at them with a shop rag, again wet with Extra, then wiped them down with a water-damp rag to rinse. This was the safest method I could find to use on the alternator. The shop rags are rough-textured for some cleaning power, but won't sling droplets like a brush.
Wire brush was used on certain aluminum or iron parts to deal with rust/oxidation, then Silvo applied with a shop rag to smooth and protect. Three months later, the aluminum heat shield over the manifold is still silky smooth. My alternator is painted, so a similar treatment could not be used on it, unfortunately, though I did lightly go over it with the wire brush during the Extra wipe-down.
Next step was treating all rubber and plastic with Mothers B2B on a cloth diaper -- though I kind of regret that now, knowing the long-term effects of B2B. Penultimate step was to dress all the rubber and plastic with Black Magic's anti-static dashboard protectant, which will help repel dust instead of attracting it like most protectants. (Next time, both steps will be covered by one application of Meguair's Vinyl and Rubber cleaner/conditioner, which is a spray and forget product that works incredibly well and doesn't collect dust.)
Finally, I went inside and bandaged the various gashes, scrapes and cuts I'd inflicted on my hands.
post Oct 25, 2005 - 5:55 PM
snapshotgt
Joined Oct 12, '05
From Texas
Thanks guys for all the suggestions...
...does anyone know how I can clean up the metal (like where the spark plugs insert)----I’ve tried---and failed to make a dent in the grime...
Anyway, thanks a lot for all the posts.
-snapshotgt
post Oct 25, 2005 - 6:31 PM
celicaST
Joined Jun 23, '05
QUOTE(snapshotgt @ Oct 25, 2005 - 4:55 PM)
-snapshotgt
[right][snapback]348947[/snapback][/right]
im not sure ive never tried it, but maybe a fine-grit abrasive paper?
post Oct 25, 2005 - 9:59 PM
snapshotgt
Joined Oct 12, '05
From Texas
QUOTE(celicaST @ Oct 23, 2005 - 10:22 PM)
[right][snapback]348229[/snapback][/right]
k, i understand what you used (what cleaning tools did you use)...but how the heck did you do such a good job??????????? it is insane, looks better than new! i tried going out there...but i can't get to all the nook and crannnies! how did you do it?
-snapshotgt
post Oct 25, 2005 - 10:07 PM
celicaST
Joined Jun 23, '05
QUOTE(snapshotgt @ Oct 25, 2005 - 8:59 PM)
-snapshotgt
[right][snapback]349045[/snapback][/right]
thanks, it just takes time thats all. i used an air hose to blow a lot of the stuff out of the tight spots first. used shop vac then to suck up all lose debris. then me and my brother just went at it with the detergent, just used regular cotton towels (going to need quite a few). we also used a lot of qtips to get in the tiny cracks which was a pain in the ***. in the end, all it takes is time and effort though, and you have to be a perfectionist, good luck and have fun smile.gif
post Oct 26, 2005 - 3:13 PM
Verde97
Joined Aug 20, '03
From Kansas City
Go to O'Reilly's or another parts store and there is a product called CD2. There are two cans in the package, one is for engine cleaning, the other for detailing. One black, one gray. Follow the directions on it, make sure that you cover up your alternator and air filter, if it is exposed. It's simple, and takes about 15 minutes and your engine bay will look better than new. Very shiny, as well. I highly recommend it, and if anyone else has used this product, I'm sure they would as well.
post Oct 27, 2005 - 9:35 PM
snapshotgt
Joined Oct 12, '05
From Texas
Well guys, i cleaned it out as much as i think i can...(i have a 2.2 L GT)...so the engine bay is a little more cramped...meaning i can't do as thorough job of getting to the tight spots...but i think it turned out well!
(click on my member name to the left...i've posted a picture)
-snapshotgt
post Oct 27, 2005 - 10:18 PM
celicaST
Joined Jun 23, '05
looks great how long did it take you? now just dont drive it so it stays that way smile.gif
This post has been edited by celicaST: Oct 27, 2005 - 10:18 PM
post Oct 27, 2005 - 10:39 PM
snapshotgt
Joined Oct 12, '05
From Texas
QUOTE(celicaST @ Oct 27, 2005 - 10:18 PM)
[right][snapback]349871[/snapback][/right]
smile.gif my guess is around an hour...but my hands!....they're a mess!...i know i'll just have to do this cleaning every so often...so i'm sure i'll get pretty good at it smile.gif
Lo-Fi Version Time is now: February 20th, 2025 - 1:07 PM
