> Clutches are a pain in the A$$, Doing my clutch.
post May 9, 2003 - 1:32 AM
CelicaGT6G
Joined Apr 5, '03
From Smithfield, RI
Im putting a centerforce Dual friction clutch in my GT. boy oh boy its a pain to have to undo just about every suspention component in the car to get to the tranny then drop it. remove the axles and stuff. ugh. sorry guys just venting. Bandit will be good to roll tomorrow night cause its been raining and i couldnet finish her till tomorrow. Peace.
post May 9, 2003 - 1:10 PM
Yeah i hear ya, but guess what, thats a cake walk once u learn how to do it. Make sure u cover the ends of the transaxles with bags, so that nothing gets on them. Make sure u have some extra codder pins too, cuz you probably destroyed the ones you had. They're cheap too, easy replace. And make sure u have a clutch disc centering tool, if u screw that up, ur clutch wont work right, and hence, screw up ur pressure plate and maybe even ur flywheel.
Oh yeah, if u havent dropped the tranny yet, bec areful, its about 80lbs.
This post has been edited by Supersprynt: May 9, 2003 - 1:11 PM
post May 9, 2003 - 9:59 PM
mywhite94celicag...
Joined Oct 30, '02
From Nebraska
when i replaced my clutch i dropped it through bottom, i figured it would be easier to do it that way then to take out the entire engine. so when i took it out i layed on the floor and lifted it out with my arms then onto my chest, then kinda rolled over to put it on the floor. then did the same thing going back in too. wiggle.gif wiggle.gif but it shouldnt take that long to take all the suspension stuff off. but good luck with the clutch, and let me know how the dual discs center force treat ya, i thought about gettin one myself. how much did you pay for it too? let me know.
94 celica GT
90 Civic Si
post May 9, 2003 - 10:01 PM
KAMiX
Joined Mar 4, '03
I'd love to change my clutch over myself (mine went about 2 weeks ago frown.gif ), but I just haven't got the experience, I have to fork out loads of money to get it done instead mad.gif
To bring down labour, what else do you think I should get the shop to do at the same time? flywheel and timing belt? others?
post May 9, 2003 - 11:29 PM
unless your doing an aftermarket light weight flywheel, why would you replace that?
post May 10, 2003 - 12:23 AM
95STCelica
Joined Oct 12, '02
From New Jersey
a mechanic quoted me $1200 just for labor to do a stock clutch replacement...so im easy with mine frown.gif
post May 10, 2003 - 12:30 AM
Teyaku
Joined May 8, '03
From Key West, FL
You know the only way to gain experience, is to do it yourself...I never messed with cars till I got my Celi...now the only thing I haven't touched is my tranny....reason is my mechanic was paid to drop the engine and tranny in...I did all the rest of the work...so now that I have my NEW freaking problem with the tranny...Guess who's getting a visit tomorrow! He'd better not have messed it up...I swear..you want something done right...you have to do it yourself...that's a univeral truth.
post May 10, 2003 - 10:35 AM
KAMiX
Joined Mar 4, '03
Super yeah thats the idea. I figure since they are going to be either machining or replacing the flywheel may as well upgrade now.
post May 10, 2003 - 7:56 PM
A flywheel is something that normally isnt replaced until extreme high mileage or, u really really dont kno how to drive.
post May 10, 2003 - 8:21 PM
KAMiX
Joined Mar 4, '03
ok I have had the car about 3 months, clutch was going when i got it, its on 120000kms, toyota dealer said the flywheel needs machining.
I don't know why you keep on with this, many people get lightweight flywheels... so I figure nows the time.
post May 10, 2003 - 8:26 PM
Whoa dont be starting with me i aint in the mood. 120,000 is alot so yes by that time i would accept the fact a flywheel might need replacing. Secondly, i said UNLESS YOUR GETTING A LIGHT WEIGHT FLYWHEEL. I dunno if u saw that. So YOUR FINE, u have high mileage, so fine, lets drop it, but i am just stating facts here aight.
post May 13, 2003 - 1:21 AM
CelicaGT6G
Joined Apr 5, '03
From Smithfield, RI
Well the clutch kit set me back 380 dollars not bad considering i got a discount from my friend. Im having touble getting the axles out there being very difficult. but as soon as im done ill tell how the centerforce works.
Lo-Fi Version Time is now: December 4th, 2024 - 4:51 PM
