> TC rims on a 6th gen
post Nov 15, 2005 - 2:41 AM
so it seems that stock 17in TC rims are a nice and cheap option for us. the tc uses the same bolt pattern and you can find these rims on ebay for around 200$....oh and it seems they are hub centric for our car! im kind of tempted to buy a pair. here is a before and after photochop of these rims on my car.
BEFORE
AFTER
post Nov 15, 2005 - 2:47 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
From what I remember the Offset makes them looked sucked in on our cars, but if you can do it and tell us how then I will be going out and buying some.
**** Photobucket
post Nov 15, 2005 - 2:53 AM
yes you are right. they are 45 offset... but so are the rims i have on there right now. gettting some 25m h&r spacers for them would be an easy fix later on.
This post has been edited by lagos: Nov 15, 2005 - 2:54 AM
post Nov 15, 2005 - 9:19 AM
Negative
Joined Apr 28, '04
From Houston, Texas
I put mine from my tC on to my 6th gen and I thought they looked too plain - but my car is silver and I think that's why. The photoshopped picture of your car above looks waaay better.
post Nov 15, 2005 - 11:12 AM
dustin15brown
Joined Aug 17, '03
From Bloomington, Indiana
QUOTE(Negative @ Nov 15, 2005 - 2:19 PM) [snapback]355797[/snapback]
post pics!!!
post Nov 15, 2005 - 11:25 AM
airswoosh1
Joined Oct 21, '05
From Los Angeles, CA
And they also have the Scion logo on the center cap right? They are still in the Toyota family, but some people may have issues putting Scion rims on a Toyota. I personally don't. I say do it!
'94 Tercel
USDM 5EFE * OEM MR-S Rims * Kumho ECSTA ASX 205/50R15 * NST Short Shifter
estabon anti-lift plates * KYB GR2 Shocks & Struts * Eibach Pro Kit * Whiteline Rear Sway Bar
Paseo Sway Bar * Paseo Front Brakes * Momo Shift Knob * Paseo Front Seats
JDM OEM Toyota Altezza Side Markers * Corsa Tailights * Corsa Grille * Corsa Trunk Garnish
http://www.socaltercel.com
post Nov 15, 2005 - 12:20 PM
Negative
Joined Apr 28, '04
From Houston, Texas
QUOTE(dustin15brown @ Nov 15, 2005 - 4:12 PM) [snapback]355820[/snapback]
post pics!!!
I can't I took them off immediately - I'm serious they looked horrible. I may have some pics of my friend's swapped '94ST with the tC rims on it when he raced it into a tree - but those pictures are hard for me to look at. So sad.
post Nov 15, 2005 - 2:27 PM
QUOTE(airswoosh1 @ Nov 15, 2005 - 11:25 AM) [snapback]355825[/snapback]
the little scion center cap comes right out, so you wont have to drive around with it saying scion on your wheels.
post Nov 15, 2005 - 2:36 PM
here is some info i found on them
# Structure: Cast Aluminum Alloy
# Size: 17x7"
# Bolt Pattern: 5x100mm
# Hub-bore: 54.06mm
# Finish: Painted "Hyper Silver" with Clearcoat
# Center caps & lugs are not included. use existing factory lugs.
http://cgi.ebay.com/ebaymotors/17x7-Scion-...013483715QQrdZ1
post Nov 15, 2005 - 2:43 PM
here are a bunch of pics of them mounted on a 5th gen.
http://www.celicatech.com/forums/vbgarage....&id=60&garage=6
post Nov 15, 2005 - 3:11 PM
95CelicaST
Joined Feb 5, '05
Well if it turns out they fit I am definately going to buy some. I as looking to get new wheels as it is, so after winter I will be looking.
**** Photobucket
post Nov 15, 2005 - 3:18 PM
they do fit... there is not doubt about that
post Nov 15, 2005 - 4:35 PM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
There's a tc in my area that has some bronze colored wheels with some rather strange spokes, they seem to be oem, they have the scion logo on them. I'd post pics but I can't find any, does anyone know what I'm talking about?
Lo-Fi Version Time is now: February 23rd, 2025 - 3:00 AM
