oil in spark plug chamber? |
Nov 19, 2005 - 11:14 PM |
Enthusiast Joined Sep 3, '04 From Avondale, AZ Currently Offline Reputation: 0 (0%) |
i have a 5sfe, and i pulled the spark plug wire out of the head and oil came out as well, i know there is a bad seal but what should i change the valve cover gasket or the head gasket??
Nov 19, 2005 - 11:19 PM |
just get a new valve cover gasket... very easy fix
Nov 20, 2005 - 10:20 AM |
Enthusiast Joined Sep 12, '05 From Who says you can't circle race a celica? Currently Offline Reputation: 5 (100%) |
Make sure you get a VCG and tube seals. Don't let em screw ya!
-------------------- 94 GT Liftback
86 GTS Coupe (Racecar) #99 Crew Chief |
Nov 20, 2005 - 10:33 PM |
Enthusiast Joined Sep 29, '05 From Rochester, Massachusetts Currently Offline Reputation: 2 (100%) |
this seems to be a common problem. This happened to me a couple weeks ago. i replaced the gaskets under the valve cover bolts (sorry dont know what it was called exactly), and it fixed my problems. Just to make sure, i also replaced the spark plugs and spark plug boots+wires. Cheap cheap, about a half hours work. have fun.
-------------------- The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed? |
Nov 21, 2005 - 12:44 AM |
Enthusiast Joined Jan 9, '03 From St. Louis Currently Offline Reputation: 0 (0%) |
hmmm, maybe this relates somehow to my problems(see other topic) I looked at one of my spark plugs in the engine and it looked like it had oil or something on it.
-------------------- [img]http://photos-081.facebook.com/n6/081/n15913038_30266081_3342.jpg[/img]
Lo-Fi Version | Time is now: January 17th, 2025 - 12:44 AM |
