emergency brake light |
Dec 8, 2005 - 5:56 PM |
Enthusiast Joined Feb 6, '03 From huntingdon tennessee Currently Offline Reputation: 1 (100%) |
I'm a little confused.... it use to be that my e-brake light on the gauges only came on when my ebrake was set. As of recently - every time i brake hard - my ebrake light comes on in the cluster.... without the e-brake engaged. This is confusing the crap outta me... i thought it might be some signal to change brake fluid or something - anyone else have this problem before?
Dec 8, 2005 - 6:24 PM |
that light comes on for 2 reasons. 1 is the ebrake and 2 is to tell you your brake fluid is low.
pop the hood and take a look at the brake fluid level. if it is low, get the car checked out to find the source of the leak. normally brake fluid should never go low on its own, and it it totally leaks out, you will have no brakes at all. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Dec 10, 2005 - 5:06 AM |
Enthusiast Joined Mar 3, '05 From Richmond, B.C. Currently Offline Reputation: 0 (0%) |
The fact it comes on during hard braking suggests it's the fluid, since it would slosh around.
If your fluid is full and the bobber to which the sensor is attached moves freely, the sensor on your actual e-brake handle may be loose. |
Dec 11, 2005 - 3:44 AM |
Enthusiast Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) |
Actually if your leaking pressure from the vaccum hose to the brake cylinder, it does that too. In other words, if there is a leak in pressure the brake comes on too. My car did that the other day and you can hear the vaccum sucking up air as the car was rolling. It scared the crap outta me too, cause I just finished installing some Subs and Amp, but make sure that you got lots of fluids and your hoses are not damaged.
Dec 11, 2005 - 10:21 AM |
Enthusiast Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) |
also check your brake pads.
Dec 11, 2005 - 1:56 PM |
Enthusiast Joined Nov 21, '05 From Nevada, TX Currently Offline Reputation: 0 (0%) |
Its the Brake Pads, thats exactly what happened to me and then it just stayed on just about all the time so i changed my pads and it whent off
Dec 11, 2005 - 2:29 PM |
Thanks for all the suggestions guys.... i've got to get to checkin all that stuff..... lol
Dec 17, 2005 - 9:05 PM |
I've officially got my problem fixed..... my pads were almost non-existent
i was also fairly low on brake fluid - fixed both of those problems and now she's back to driving like a dream..... well sort of (besides the fact that it's still slow as poo) -------------------- |
Lo-Fi Version | Time is now: January 12th, 2025 - 12:28 AM |
