> jdm 7afe wont give any spark from distributor
post Dec 24, 2005 - 10:23 PM
st_celica_killer
Joined Sep 23, '04
From fresno
I'm having problems with my new jdm 7afe that i just bought, Somehow i crank the car but cant seem to start the car. I check out everthing from wire to fuse but everything seem to work somehow its not getting any spark from the spark plug wires so i went ahead and bought a complete new distributor with cap, rotor including a new set of ngk wires and its still not getting any spark from the engine...any help????
post Dec 25, 2005 - 2:10 PM
st_celica_killer
Joined Sep 23, '04
From fresno
bump! come on help
post Dec 25, 2005 - 7:22 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Could be your coil or ignitor. Check them both out.
Click here to see my swaps
drtweak@phoenixtuning.com
post Dec 26, 2005 - 12:56 PM
st_celica_killer
Joined Sep 23, '04
From fresno
its still not working even though i replaced them with new ones !
post Dec 26, 2005 - 8:05 PM
R-03
Joined Oct 30, '03
From TEXAS-1
that new distributor you put in, did it have all new internals? if not you might want to replace the condenser inside the dist. under the cap. it's the little firecracker looking part inside the cap. will only cost you about $3-$4. if not that, make sure there aren't any frayed or pinched wires along the ignition sysytem.
post Dec 26, 2005 - 11:46 PM
Dr_Tweak
Joined Mar 31, '04
Check to make sure you're getting power at the coil and ignitor.
-Doc
post Dec 27, 2005 - 10:15 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
check to make sure that the JDM wiring will actually work with the USDM wiring. You might have a wiring problem. If I am correct, JDM does not have that *Thingy* (oh man im getting rusty on skills not working on my car for a month now....) that regulates smog and stuff.
post Dec 27, 2005 - 11:40 PM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
^egr
This post has been edited by JoKeRkId613: Dec 27, 2005 - 11:40 PM
post Dec 28, 2005 - 2:36 AM
st_celica_killer
Joined Sep 23, '04
From fresno
alright so i decied to took the car to a shop..and they told me that everything seems to be working but they cant seem to find the problemss..so i might think that the motor went out on me....back to the drawing board...urghhhhhhhh.
post Dec 28, 2005 - 6:22 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
I was just down there in Fresno for the new year... I coulda check it out for you... =/
Umm... when you crank the car... does the tach move at all?
Lo-Fi Version Time is now: November 24th, 2024 - 12:40 PM
