> Cams Sprockets, under pulleys,cams, drive power pulley
post May 19, 2003 - 11:45 PM
H8DC3lica94
Joined Jan 29, '03
From San Diego, CA
i know that the cam is for the timing belt and the under pulley is similiar to that but found in the lower portion of the engine.
Dont really know where the drive pulleys go..
I have a 7a-fe engine and i'm looking for some hp increase.
Obx offers these parts for the corolla. but i cant find a dealer.
Chris Malaqui
Non-running Celica
post May 20, 2003 - 7:34 AM
edo17982
Joined Dec 21, '02
From Italy
cam gear(s) is in the end of the camshaft, linked to the timing belt.an adjustable one let you change the timing to better tune your engine
Underdrive crank pulley is like the original one but is lighter and the accessory section is smaller to have a lower resistance.
overdrive accessory pulleys have the same function of reduce weight and rotational mass by increasing the size to let the accessories run slower. wink.gif wink.gif wink.gif
it seems that OBX products are impossible to have....If you can have one of the stuff you listed let me know cause I want them too!!! biggrin.gif biggrin.gif
This post has been edited by edo17982: May 20, 2003 - 2:58 PM
Lo-Fi Version Time is now: November 27th, 2024 - 11:39 PM
