> 7AFTE ready, but dont get the turbopressure lower then 1.2 Bar.
post Jan 29, 2006 - 8:46 AM
Conwa
Joined Nov 5, '05
Yes, the installation of the turbo is done!
Everything is working fine.
Doesnt leak any oil or cooling fluid.
little leak on the exhaust manifold but thats it.
I installed a missing link valve from a Honda between the map sensor, but dont know its working because i got the following problem:
When im starting the engine its all fine, but when riding the turbopressure begins very quickly and raises till 1.2 Bar!
I dont have a Actuator on it, because the guy the made en provided the turbo made a bolt that can be adjusted, the problem now is when i adjust it, it doesnt make big difference in turbopressure, it keeps getting to high.
I gonna look for a Actuator now, to find out this is the problem.
I cant drive it now, because the boost begins when giving 1/4 throttle and raises quickly till 1 Bar.
This post has been edited by Conwa: Jan 29, 2006 - 9:00 AM
post Jan 29, 2006 - 10:03 AM
NuclearHappineS
Joined Oct 17, '04
From St Louis, MO
listen man, the missing link is just a check valve before your map sensor ...
how're you you fueling your car ?
the boost issue has nothing to do with your map sensor ...check your wastegate flapper and your actuator and the vacuum lines running to it...
2005 MB C200 Kompressor- K&N, Apexi WS2 Catback, DIY Voltage stabilizer, Intrax Springs, H&R RR swaybar, VDO Boost Gauge @ 6psi, Greddy L7 plugs, +0 Rear tires
To Do: E-manage Ultimate tuned up to 12psi
post Jan 29, 2006 - 10:31 AM
Conwa
Joined Nov 5, '05
Lol i know the mlv got nothing to do with that, i only mentioned it to be on my car.
I dont got a actuator and thats the problem, i can adjust the wastegate by hand so i can set it open or closed. when openend there supposed to be a low pressure raise in the turbo, but i think its not working because it keeps getting above 1 bar.
Its a turbo from a Toyota Previa TDI from 2004.
A mate of mine made it fit on my exhaust manifold but the wastegate on a Previa is electronic (i think) so he had to make an other way to adjust the pressure.
This post has been edited by Conwa: Jan 29, 2006 - 10:54 AM
post Jan 29, 2006 - 12:02 PM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
u boosted your car and didnt put a WG/ actuator on it... oh boy. i forsee a future post. blown motor...
post Jan 29, 2006 - 12:09 PM
dude smack the guy who said don't use a wastegate actuator...
your goin to blow your motor really really fast....
thats wat? umm i thnk 17psi....yea your wastegate isn't opening at all and just boosting through the roof..
post Jan 29, 2006 - 1:18 PM
Conwa
Joined Nov 5, '05
i can adjust wastegate by hand, but when im adjusting it to much the engine doesnt start or it dies at 2000 rpm. So im not sure which way to adjust it to.
post Jan 29, 2006 - 2:04 PM
wuzup43215
Joined Jan 27, '06
From VA
the wastegate, if it was electronic might not be woring right, now that you changed it. you must get one. you should only boost like at about 10 or 11 psi on a stock motor for a daily driver.
post Jan 29, 2006 - 3:29 PM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
^yea right. if u have a 3s then you can pull off doing 10-12psi daily. not with a 7a or 5s unless u have another one laying around. u could boost them that high and they'll be fine, just dont do it eveyrday
post Jan 29, 2006 - 9:45 PM
just cause you can adjust it by hand doesn't mean its opening...
you see as you boost the wastegate graduatly opens via vac/boost pressures to maintain a boost level YOU HAVE to have an ACTUATOR to do this..
post Jan 29, 2006 - 9:53 PM
QUOTE(Conwa @ Jan 29, 2006 - 8:46 AM) [snapback]385987[/snapback]
did you even bother to do any research on how a turbo works ?
post Jan 29, 2006 - 11:11 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
This thread sucks. Who in their right mind would boost a car and not use a traditional wastegate actuator? Why even bother?
post Jan 30, 2006 - 1:35 AM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
There's no wastegate because the turbo is from a diesel. You must get an external one.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Jan 30, 2006 - 2:54 PM
holy crap.........
a diesel....wtf
post Jan 31, 2006 - 1:37 PM
Conwa
Joined Nov 5, '05
Yeah i figured that out already, so i ordered a external one from the US, i hope that that works properly.
And to y'all im not stupid and i know how a turbo works i've had turbo'd cars before and did ALOT of research on 6gc and other sites and books, but never did a dieselturbo on a Petrol car.
Also didnt we knew that the Turbo hadnt a wastegate but some flood regulation.
Lo-Fi Version Time is now: November 27th, 2024 - 8:56 AM
