i know, silly ?, what is the right tire presure for a celica ? |
Feb 7, 2006 - 4:04 AM |
Enthusiast Joined Nov 24, '04 From Moscow, russia Currently Offline Reputation: 0 (0%) |
Like it says.........
i'm running on R16 225 x 50, and the pressure is at two atmosphere's (not sure how that traslates to lb) what tire presure should i have, and should it be less in winter ? thanks -------------------- Life is for living, and you don't get a second chance Take care now !! |
Feb 7, 2006 - 4:19 AM |
Enthusiast Joined Jan 9, '05 From Under the car Currently Offline Reputation: 0 (0%) |
I run 34PSI all year round unless it snows in which case I run 30PSI.
Feb 7, 2006 - 5:56 AM |
Enthusiast Joined Jan 30, '06 From good old blighty Currently Offline Reputation: 0 (0%) |
QUOTE(popstar @ Feb 7, 2006 - 4:04 AM) [snapback]390067[/snapback] Like it says......... i'm running on R16 225 x 50, and the pressure is at two atmosphere's (not sure how that traslates to lb) what tire presure should i have, and should it be less in winter ? thanks MY translated handbook recommends a tyre pressure of 35psi allround for the standard tyre size (215x50_16), so thats what i put in to the 225x45_16's i'm running. Check the link below for tyre pressure conversion... http://www.caravanninglinks.co.uk/Tyres.htm regards 4C. |
Feb 7, 2006 - 6:53 AM |
ok so from that, i'm running a little under pressure then.........
i need to get a tire pressure gauge and re check all my tires... thanks guys This post has been edited by popstar: Feb 7, 2006 - 6:54 AM -------------------- Life is for living, and you don't get a second chance Take care now !! |
Feb 7, 2006 - 8:24 AM |
Enthusiast Joined Aug 20, '03 From Annapolis, Md Currently Offline Reputation: 5 (100%) |
It also depends on the type of tire. If anyone is like me, i dont have all 4 same wheels, and there all dif. but i average them all out about 40psi
Feb 7, 2006 - 9:29 AM |
QUOTE(Digndoug @ Feb 7, 2006 - 8:24 AM) [snapback]390082[/snapback] It also depends on the type of tire. If anyone is like me, i dont have all 4 same wheels, and there all dif. but i average them all out about 40psi I think if you've got a 2wd Celica you can do this, but i have a GT4 and have to have the same tyre size and pressure as the wheels are all in sinc.... 4C. |
Feb 7, 2006 - 1:00 PM |
Enthusiast Joined Nov 12, '03 From Crestview, Florida Currently Offline Reputation: 2 (100%) |
Working at Discount, normally set them at an average of 32-35 psi. Just look on the inside of the door and itll give you recommended PSI.
Feb 7, 2006 - 6:29 PM |
Enthusiast Joined Aug 20, '03 From Kansas City Currently Offline Reputation: 0 (0%) |
I agree with BLINKYxMUNKEY. Also, if you check your max tire pressure on the tire itself, just go about 3 psi less, and you will be in good shape.
Feb 7, 2006 - 6:47 PM |
Enthusiast Joined Mar 25, '05 From Sydney, Australia Currently Offline Reputation: 0 (0%) |
Mine are normally at 34 psi.
-------------------- 98 ST204 ZR - Black Beauty - Roaming the streets of Sydney 73 TA22 LT - Tiffany Blue - Mint Classic Weekend Cruiser 75 TA22 LT - Snow White - Mint Classic Weekend Cruiser 77 RA28 LT - Flubber Green - Mint Classic Weekend Cruiser 94 MX-5 NA8 Clubman - Red Racer - Looking for corners WIP Project: 69 RT40 Corona, 2nd WIP Project: 66 RT40 1600s Corona 86 Corona RT142 - Daily Driver 6GC 4 Life Baby!!! |
Feb 7, 2006 - 10:12 PM |
Enthusiast Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) |
I also suggest going what is on the tire.. I do 40 to 42 psi and I get great tire wear
-------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Feb 8, 2006 - 1:10 AM |
QUOTE(4candles @ Feb 7, 2006 - 9:29 AM) [snapback]390101[/snapback] QUOTE(Digndoug @ Feb 7, 2006 - 8:24 AM) [snapback]390082[/snapback] It also depends on the type of tire. If anyone is like me, i dont have all 4 same wheels, and there all dif. but i average them all out about 40psi I think if you've got a 2wd Celica you can do this, but i have a GT4 and have to have the same tyre size and pressure as the wheels are all in sinc.... 4C. that is the best set up..... i'm running a different profile front to back right now due to having to get two new tires and not being able to get 50's so i got 55's......... and at $200 a tire i wasn't about to get four at once <:( (money don't come cheap) i'll replace the old tires soon aswell, i'm not sure what the long term effect will be from running two different prifiles....... apart from an unbalanced car....... ?????? -------------------- Life is for living, and you don't get a second chance Take care now !! |
Feb 8, 2006 - 7:53 AM |
If you overinflate the tire it will wear the middle of the tire down. If you underinflate it will wear the outside of the tire.
^note -------------------- |
Feb 8, 2006 - 12:28 PM |
Enthusiast Joined Dec 28, '05 From USA Currently Offline Reputation: 0 (0%) |
make sure you check the pressure COLD, meaning leaving the car undriven for a couple hours to let it cool, pressure in your tires increase as you drive it, so if u want 35 psi, make sure you do it cold
Feb 28, 2006 - 1:37 PM |
Enthusiast Joined Aug 21, '03 From UK Liverpool Currently Offline Reputation: 0 (0%) |
Should say on the tire, if not i put about 30psi in. Also should tell you on your door well.
Feb 28, 2006 - 10:19 PM |
QUOTE(Nigel @ Feb 28, 2006 - 1:37 PM) [snapback]400922[/snapback] Should say on the tire, if not i put about 30psi in. Also should tell you on your door well. On the tire, it says the max pressure, which is problably around 60 lbs of air. The recommended tire pressure is on a sticker inside the door. -------------------- |
Feb 28, 2006 - 10:37 PM |
READ THE SIDE OF THE TIRE
Feb 28, 2006 - 11:49 PM |
Enthusiast Joined Jan 16, '06 From Lima, ohio Currently Offline Reputation: 0 (0%) |
^^ u beat me to it, it all depends on the tires
Nov 19, 2007 - 7:58 AM |
Enthusiast Joined Apr 17, '07 From Greece Currently Offline Reputation: 0 (0%) |
QUOTE(playr158 @ Mar 1, 2006 - 5:37 AM) [snapback]401145[/snapback] READ THE SIDE OF THE TIRE This is the maximum pressure the tyre can handle, not the optimal!! I read somewhere that a good pressure is ~10% less than that value. -------------------- |
Lo-Fi Version | Time is now: December 12th, 2024 - 10:39 AM |
