> B16 Exhaust Manifold on 7AFE, B16 Exhaust Manifold on 7AFE
post Mar 1, 2006 - 10:33 PM
juan_solid
Joined Dec 22, '05
From Turlock, CA
I have previously seen some pictures of the b16 T3 turbo exhaust manifold on a 7AFE engine. I would like to know If anyone can tell me what modifications I need to make to the flange in order to make this work. ANY input is appreciated. This is the manifold I want to get on ebay at:
http://cgi.ebay.com/ebaymotors/NEW-Civic-I...041461498QQrdZ1
www.cardomain.com/id/snakesolid
post Mar 1, 2006 - 10:58 PM
dans_st
Joined May 24, '03
From Andrews TX
I posted a topic over this a while back I'll see if I can find it for you
If anyone is missing NASCAR and it's not on Speed Channel, take a fistful of Skittles, throw them in the toilet and hit the flush handle. Instant NASCAR!!!
post Mar 1, 2006 - 11:01 PM
its in teh STICKIES wink.gif "7afe maps and ect."
you have to cut the manifold's flange off (the engine side)
and weld on a 7afe flange (runner extension might be needed)
flanges available from jgstools.com/turbo
also you need to reinforce the welds on that manifold as they are know to crack and a brace (if it doesn't come with one) should be welded from flange to flange to aid in support
post Mar 1, 2006 - 11:13 PM
dans_st
Joined May 24, '03
From Andrews TX
in the stickies I beleive that that is Nik's manifold which is the 4AGE head for his 7AGTE as for the 7AFE you will have to move the exhaust runners that connect to the JGS flange, you will especially have to move the runners from thew #1 & #4 cylinders
on the post that I had made some one (sreetracing10-12psi I think confused.gif ) put up some close-ups of a finished B16/18 manifold on the 7AFE
BUT basically the 4AGE head lines up but the 7AFE has to be modifeid quite a bit
post Mar 1, 2006 - 11:55 PM
actually i wrote 1 of the stickies the one which i mentioned in my last reply and it was clements car which is a 7afe wink.gif
post Mar 2, 2006 - 3:18 PM
dans_st
Joined May 24, '03
From Andrews TX
check this out.
http://www.6gc.net/forums/index.php?showtopic=30398&hl=
post Mar 2, 2006 - 9:09 PM
juan_solid
Joined Dec 22, '05
From Turlock, CA
Lo-Fi Version Time is now: November 25th, 2024 - 12:42 PM
