> 3rd plug for ecm 3sgte conversion, is it included with the dash harness???
post Mar 13, 2006 - 6:00 AM
toyotacrazy
Joined Mar 4, '06
From Ohio
Hey, Does anybody know which harness the 3rd plug for the ecm is located. . If I'm correct there is one plug that usually isnt included with the ecm unless you buy the entire clip. I think its with the dash harness. Thanks for your help!!!!!!!!!!!!
post Mar 13, 2006 - 7:12 AM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
That's right, it comes from the dash harness, however you have a 22-pin plug in your GT that will work just fine, you just need to repin/rewire it.
Also, some good importers will include the third plug, this is usually the case when I buy engine sets.
-Doc
This post has been edited by Dr_Tweak: Mar 13, 2006 - 7:12 AM
Click here to see my swaps
drtweak@phoenixtuning.com
post Mar 14, 2006 - 3:29 AM
Speedy2k
Joined Jan 6, '06
From Toronto, Canada
Tweak,
I am trying to get my A/C to work. I understand that the 3rd plug is responsible for turning on the compressor. Do i just repin that plug to match the wires on my interior harness?
post Mar 14, 2006 - 7:16 AM
Dr_Tweak
Joined Mar 31, '04
Sort of, yeah. You have to make sure the black/white wire to the a/c compressor clutch is hooked up.
-Doc
Lo-Fi Version Time is now: November 28th, 2024 - 3:26 PM
