> Power Enterprise Cam Controller
post Mar 17, 2006 - 1:12 PM
frosty
Joined Sep 1, '04
From Alabama
Hey, I found this cam controller for all toyotas with the vvt-i / vvtl-i . I've been reading a bit about it and it seems pretty good. I was just wondering if anyone here has either heard about it or are using it on the beams? I also curoiuse about it since my wifes new celica has vvt-i (sad that it's the 1zz-fe and not the 2zz-ge) No sites really specify if it's used on the 6gc with vvt-i but most say all toyotas with it can use it.
Also, what kind of hp gain do you think could come from it?
CLOSED on 25 acres!
-shop coming soon....
post Mar 17, 2006 - 10:34 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
vvt-i is designed to generate a solid torque curve... so no... if put on a stock motor... you'll probably lose power. vvt-i is computer controlled and adjusts cam timing itself based on load, tps, etc... so it's very hard to out-do the computer. The only time this may be beneficial is when you're running performance camshafts and the computer can't quite get the proper timing for the cam...
Lo-Fi Version Time is now: February 22nd, 2025 - 12:55 AM
