Need Help!, removing.. |
Mar 24, 2006 - 6:16 PM |
Enthusiast Joined Jan 18, '06 Currently Offline Reputation: 0 (0%) |
Can sum1 tell me how to remove the dash so i can take out my cassette player plz..
Mar 24, 2006 - 6:28 PM |
Enthusiast Joined Jan 16, '06 From Lima, ohio Currently Offline Reputation: 0 (0%) |
just pry it out
Mar 24, 2006 - 7:17 PM |
Enthusiast Joined May 6, '05 From PA Currently Offline Reputation: 4 (100%) |
Remove shifter trim first, it just pulls right up. Then theres two screw underneath it. THEN pry it up.
Mar 24, 2006 - 8:25 PM |
i bought my car used, and they had unscrewd the screws and not put them back in
Mar 24, 2006 - 11:14 PM |
Enthusiast Joined Oct 12, '05 From Texas Currently Offline Reputation: 59 (100%) |
here is part of a "how-to" on doing something that requires taking this part off...
"The first step is to remove the panel that surrounds the shifter. This panel simply pulls out and is held in by four clips. Once that panel is off, you'll need to remove the panel that is directly above it. First remove the two screws from the bottom of the panel, and then pull the panel out. It is held in by a few clips, and is attached to two harnesses near the top. These will need to be unclipped before you can remove the panel." Enjoy ~snap -------------------- Past: V6 Swapped 6G Celica, E46 BMW M3, Jeep Wrangler TJ
Current: 850rwhp C6 Corvette Grandsport, Gen1 6.2L Ford Raptor |
Mar 25, 2006 - 6:24 AM |
Enthusiast Joined Mar 14, '05 From Auckland,New Zealand Currently Offline Reputation: 1 (100%) |
If it is auto. Use the Red button and move the gear into D or one of the other gears.
Mar 25, 2006 - 12:58 PM |
ohh i finally got it...thanx fer the help =]]
Lo-Fi Version | Time is now: November 30th, 2024 - 7:25 PM |
