> Clutch Problem
post Mar 25, 2006 - 2:05 AM
3sgte@daspeedof
Joined May 23, '05
From Sauga
Ok, so I've run into another problem, I was trying to bleed my clutch, but I can't even press down on the clutch pedel, so I open up the bleeder valve by the clutch fork or the slave cylinder. When I press on the clutch with the valve open, the clutch goes all the way to the floor, and it pumps out the fluid with ease. As soon as I close the valve the clutch pedel locks up and I'm not able to step on it at all again.
post Mar 25, 2006 - 10:23 AM
3sgte@daspeedof
Joined May 23, '05
From Sauga
Bump anyone have any ideas?
post Mar 25, 2006 - 11:24 AM
you have to pump the clutch pedal with your hand.
post Mar 26, 2006 - 10:20 AM
3sgte@daspeedof
Joined May 23, '05
From Sauga
Just wanted to say thanks for the help, I pulled the slave cylinder & stepped on the clutch, and the piston didn't move at all, so I'm under the impression that my slave cylinder is no good, what would cause that, cuse before my clutch swap it was moving fine?
post Mar 26, 2006 - 11:36 AM
oil contamination could have caused the lip seals and O-rings to swell and lock it into place.
post Mar 26, 2006 - 9:40 PM
3sgte@daspeedof
Joined May 23, '05
From Sauga
Ok, so how do I blead or better yet flush the whole system?
Lo-Fi Version Time is now: November 27th, 2024 - 1:02 AM
