> turn signals, are they on when your headlights are on
post Mar 28, 2006 - 5:14 AM
pandakid
Joined Feb 12, '06
From Fresno CA
yea i don't know but i wanna see if its normal, when you turn your head lights on do your turn signal are on? cuz the only thing that on is my fog,side, and head light. are your turn signals supposed to be on as well?
post Mar 28, 2006 - 5:41 AM
CelicaZR
Joined Mar 25, '05
From Sydney, Australia
I'm not sure what you are asking.
But I think you mean, if your headlights is not on does
6GC 4 Life Baby!!!
post Mar 28, 2006 - 6:27 AM
94wrc
Joined Mar 24, '06
From Slough,Berkshire,UK
I think the US ones have the indicators on constant with the headlights unlike others.
Nathan
1994 JDM ST205 WRC with 17" OZ Chrono's wearing 215/45/17 Eagle F1's. HKS Induction Kit, Blitz DV, Decat and full SS System, Blitz SBC-iD and Power Meter running at 1.12Bar = 17mpg and a lot of fun
post Mar 28, 2006 - 11:24 AM
JFrost9
Joined Aug 27, '05
From Texas
Yea, if you have fogs that came installed, you should have the switch on the side of the lil stick. The first notch is the turns/sides... the 2nd notch is the headlights. Then thers a side switch with the fogs.
This post has been edited by JFrost9: Mar 28, 2006 - 11:25 AM
post Mar 28, 2006 - 3:19 PM
pandakid
Joined Feb 12, '06
From Fresno CA
oh i confussed you you guys here i'll take a picture later when its darker. so you can see what i mean
post Mar 28, 2006 - 3:51 PM
CanadaCelica
Joined Sep 24, '04
From Kitchener, Ontario
I think I know what you mean.
Lets say I have my lights all the way off, only thing that is on for me are my day time lights.
Then if I turn the light switch once I get all my indicators and rear lights on, including the turn signals lighting up. Only lights that won’t be on are my low beams, day times will still be on in this setting.
If I turn the switch once more then my low beams come on and all the other indicators etc previously mentioned are still on.
So yes when my lights are on the turn signals do light up. Well for me anyway, and when I use the turn signal like this they just blink brighter.
post Mar 29, 2006 - 4:21 PM
pandakid
Joined Feb 12, '06
From Fresno CA
ok are these suppoed to be on when my head lights are on?
Cause right here my head lights,side markers,and fog lights are on. my turn signals are on when i make turns.
post Mar 30, 2006 - 2:22 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Yes, those should be on at all times the engine is on. They, like the signals in the rear, are dual-filament bulbs so that the illumination level can have three settings: off, single filament (what you get when the engine is on) and dual filament (what you get when signalling).
post Mar 30, 2006 - 4:01 AM
pandakid
Joined Feb 12, '06
From Fresno CA
oh im gonna check my fuses then. thanks unless anyone has any ideas to fix it
post Mar 30, 2006 - 7:07 PM
Scott
Joined Apr 19, '05
the front turn signals should be on 50% when headlights are on-same as parking lights. more than likely, the less bright of the two filaments is burned out. try replacing the bulb.
post Mar 30, 2006 - 10:24 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
but its kind of odd that they burned out at the same time IMO
post Mar 30, 2006 - 11:52 PM
pandakid
Joined Feb 12, '06
From Fresno CA
yea checked my fuse and none are broken.must be something else i'll try buyin gnew bulbs
post Mar 31, 2006 - 6:53 PM
ILuvMyCelica95
Joined Dec 16, '02
are you guys sure about this? cause im pretty sure my turns are not on when the headlights are. I have to go check this out now.
post Apr 1, 2006 - 3:57 AM
pandakid
Joined Feb 12, '06
From Fresno CA
yea post pics pleaase it help me out and the year
post Apr 1, 2006 - 2:19 PM
JFrost9
Joined Aug 27, '05
From Texas
Yes the turns/sidemarkers are on when the first notch is turned. And then when the 2nd notch is turned on the headlights come on with the sides and turns. Do yours ever turn on? Or do they just blink? Its very simple.
This post has been edited by JFrost9: Apr 1, 2006 - 2:20 PM
post Apr 1, 2006 - 5:14 PM
pandakid
Joined Feb 12, '06
From Fresno CA
they just blink
Lo-Fi Version Time is now: February 25th, 2025 - 11:09 AM
