> Got my 3sgte
post Apr 10, 2006 - 5:53 PM
bigal004321
Joined Jun 21, '05
From New york
Si finally got my 3sgte clip in today..So excited to put it in now. I was jsut wondering where the ECU is located in the cars. Is it usually behind the center console or underneath the seat. Cuz if it is underneath the seat then i didnt get one with it. ANd if i didnt get one with it do i just use my 5sfe one?
Bigal
EDIT: how can you tell whether it is a 1st or 2nd gen? and I will have a few pics up of it tonight..
This post has been edited by bigal004321: Apr 10, 2006 - 5:55 PM
1994 celica GT.....3sgte in a month! all helpers are welcome!!! i live in Plattsburgh, NY.
post Apr 10, 2006 - 5:57 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
its under the center console. way way below the radio. get to it from either the passenger or driver side under the dash.
post Apr 10, 2006 - 5:58 PM
bigal004321
Joined Jun 21, '05
From New york
QUOTE(x_itchy_b_x @ Apr 10, 2006 - 6:57 PM) [snapback]419891[/snapback]
Thank you
Now the wiring harness i need is only what goes to the ECU or do i pull just about every wire to convert it?
This post has been edited by bigal004321: Apr 10, 2006 - 6:01 PM
post Apr 10, 2006 - 6:14 PM
Chanh55
Joined Jun 29, '03
QUOTE(bigal004321 @ Apr 10, 2006 - 3:58 PM) [snapback]419892[/snapback]
Thank you
Start pulling from the ECU then pull it through the firewall from the engine bay, whatever is connected to these wires will be part of the wiring harness. You need to do this for both your old engine and the new one for the conversion.
post Apr 10, 2006 - 6:22 PM
bigal004321
Joined Jun 21, '05
From New york
Doesnt seem to be too tricky.
Bigal
post Apr 10, 2006 - 8:30 PM
bigal004321
Joined Jun 21, '05
From New york
How do you tell the difference between 1st and 2nd gen 3sgte?
Bigal
post Apr 10, 2006 - 9:00 PM
BBoYRuGGeD
Joined Jun 4, '04
From Northern New Jersey
QUOTE(bigal004321 @ Apr 11, 2006 - 1:30 AM) [snapback]419946[/snapback]
Bigal
1st gens got w2a tmic and 2nd gens got a2a tmic..easiest way to tell
bboy
post Apr 11, 2006 - 12:06 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
w2a = water to air, kinda like an intercooler in a bucket of cold water.
a2a= air to air, typical intercooler setup.
1st gen with w2a ^
2nd gen with a2a ^
post Apr 11, 2006 - 12:30 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
first gens had w2a also?
why would they seem to downgrade to the 2nd gen.
post Apr 11, 2006 - 11:45 PM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
It was probably cheaper and much simpler for Toyota to produce and bolt up a A2A at the time as opposed to having to use a W2A and do the extra plumbing, wiring, heat exchanger, etc.
Nothing wrong with a good TMIC thats A2A, as long as its designed well enough not to soak up alot of heat and be efficient with boost.....something that I've read Toyota missed the mark with on the 2nd gen motor.
Lo-Fi Version Time is now: November 24th, 2024 - 12:45 PM
