Enthusiast ![]() Joined May 23, '05 From Sauga Currently Offline Reputation: 0 (0%) ![]() |
I thought it was my starter, so I swapped it out. I took in my battery and it wasn't holding a charge so I got a new one and it still won't start. What else would cause this? what specific sensors am I looking at?
Enthusiast ![]() ![]() ![]() Joined Dec 5, '05 From LA, CA Currently Offline Reputation: 1 (100%) ![]() |
We need more info... do you hear the starter clicking? have you checked all your plugs? is the motor turning over at all? Have you checked your fuses?
etc... -Charlie -------------------- 2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid 1988 Camry Alltrac LE - BEAMS swap started |
I haven't checked my fueses gonna check those, and my coil & ignitor, don't know what else it could be
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '03 From Wichita, KS Currently Offline Reputation: 5 (100%) ![]() |
I checked your other thread here:
http://www.celicatech.com/forums/showthrea...1175#post181175 Now that we know it's cranking, can you tell us if you have spark or fuel? Have you checked the trouble codes? If you have both spark and fuel and no codes you'll want to check timing next. -------------------- ![]() Project ST204.5 99.88946% complete... |
I found out that my efi fuse was blown, hence the reason it wouldn't start, duh!!
I know I overlooked the little thing of just checking my fuses. But when I ran my cel codes it came back with two cel errors. 24 & 32, would they cause me to only be reading 6psi on my boost gauge? And what else would cause this? Now today, Its only hitting 5psi |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) ![]() |
24 - AIR Open or short circuit in Air Temp Sensor Check Air Temp Sensor
32 - AFM Open circuit or short in E2 signal Test or replace Air flow Meter so everyone doesnt have to search |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 29, '03 From 캘리포니아 Currently Offline Reputation: 23 (100%) ![]() |
I thought code 31 was for AFM short or open.
QUOTE(MaskedMan @ Apr 22, 2006 - 1:32 AM) [snapback]424708[/snapback] I thought code 31 was for AFM short or open. ![]() -------------------- ![]() Project ST204.5 99.88946% complete... |
yea I read it, I'm hoping its not my afm but thats what things are leaning towards, without me checking the voltage I won't know for sure though
Lo-Fi Version | Time is now: February 23rd, 2025 - 6:34 AM |
