> 4A-GZE for 5S-FTE injectors
post Apr 21, 2006 - 10:32 PM
swerve
Joined Mar 18, '06
From Brisbane - Australia
Hi Guys,
Am trying to find some injectors for the turbo install into the 5s-fe. I have already purchased some side feed supra injectors, so obviously they won't do mad.gif
Does anyone know if 4A-GZE injectors will fit. Found a nice 365cc Biltz set I am looking at. Part number - 23250-16061. They seem to be a top feed 2ohm impedance.
Thanks
This post has been edited by swerve: Apr 21, 2006 - 10:33 PM
post Apr 22, 2006 - 3:21 AM
no, they wont be plug and play, you need top feed, high impedance injectors.
post Apr 22, 2006 - 5:47 PM
swerve
Joined Mar 18, '06
QUOTE(presure2 @ Apr 22, 2006 - 6:21 PM) [snapback]424727[/snapback]
hmmm. do you know if there is something we can use larger than the 315cc from the supra, but smaller than the 440 off the RX7. I am using a piggy ECU, and my tuner thinks that 440cc may be too big to control whilst not under boost. Would prefer larger than 315 though.
post Apr 22, 2006 - 6:00 PM
get the 440s, youll be fine. anything smaller could cause you to run too lean
Lo-Fi Version Time is now: February 23rd, 2025 - 10:41 PM
