Could someone post a Exlploded view of the front DS Spindle/AXLE |
May 9, 2006 - 7:48 PM |
Enthusiast Joined Apr 5, '06 From PITTSBURGH, PA Currently Offline Reputation: 0 (0%) |
I found a spinde at a junk yard about 15min away. I need a exploded view of the drivers side front spindle and axle, Drivetrain. If some one has them that would be awesome if you could post them. I gong to take this apart tomorrow and a diagram would be a great help. Thanks in advance I do have one question, What size is the Largest socket needed to get this done?
This post has been edited by Celi94bk: May 10, 2006 - 4:29 PM |
May 11, 2006 - 9:54 AM |
"It's a 30mm nut. A 1-1/4" socket will work too, and is more commonly available."
This is for the center drive shaft bolt. No one corrected me on this I was running around looking for a 33mm and no one had one... lol Anyways I did not want to mess any one up. I need to get a 30mm or a 1-1/4 socket back out to the store. I have the nuckle it is in ruff shape so im going to try and clean it up a bit and I will let you know how it went.. |
May 11, 2006 - 11:17 AM |
QUOTE(Celi94bk @ May 11, 2006 - 10:54 AM) [snapback]432833[/snapback] "It's a 30mm nut. A 1-1/4" socket will work too, and is more commonly available." This is for the center drive shaft bolt. No one corrected me on this I was running around looking for a 33mm and no one had one... lol Anyways I did not want to mess any one up. I need to get a 30mm or a 1-1/4 socket back out to the store. I have the nuckle it is in ruff shape so im going to try and clean it up a bit and I will let you know how it went.. I was reading on through some of the forums and found out that it was a 32mm socket so I went and purchased it and no.... It is not the right one it is a little too small.. I have a 94 GT does this matter because the socket that I purchased does not fit. I purchased a 32mm socket and it does fit.. now im thinking about it the socket might not be deep enough.. hmmm... back to the parts store 3 times now I GOT THE NUT OFF >>>LOL 32mm Axle Socket.... Black worked very well This post has been edited by Celi94bk: May 11, 2006 - 1:25 PM |
Lo-Fi Version | Time is now: December 3rd, 2024 - 6:10 PM |
