Enthusiast ![]() ![]() Joined May 2, '06 From Nevada Currently Offline Reputation: 0 (0%) ![]() |
Hi,
My power antenna at the last inches of extension makes horrible noises like it is stuck trying to extend - real bad and loud. Any ideas howto fix it? Thanks! |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Portsmouth, RI Currently Offline Reputation: 33 (100%) ![]() |
thats exactly what mine does. and sometimes it wont go down by itself either, it'll just make that noise... it needs a little push when that happens
i took it out to try and figure out the problem and theres a little piece of the end missing from the plastic thing that pulls it down get a new one or live with it...theres not much else you can do. im just going to disconnect the motor [one of these days] so it stays down, i never liked that huge thing sticking up all the time anyway hope that helped ![]() -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 1, '02 From Seattle, WA Currently Offline Reputation: 0 (0%) ![]() |
That same thing happened to me a whle back ago. It also happened to my mom's camry as well.
My fix was ripping out the power antenna, disconnect the power cable and install an s2k antenna. My moms fix was trading her car in for a lexus. I think others here with the same problem installed a new motor. -------------------- Its Orville's Celica, i just drive it... |
Enthusiast ![]() Joined Dec 28, '05 From Norway Currently Offline Reputation: 0 (0%) ![]() |
Or you can just replace the antenna mast, the thing that extends, the antenna itself.
yeah its not the motor...that obviously works since your hearing it
you could just replace the antenna mast and plastic thingy but i like the trade for a lexus idea...that works too, do that ![]() -------------------- |
Enthusiast ![]() ![]() Joined Jun 30, '05 From Chattanooga, TN Currently Offline Reputation: 5 (100%) ![]() |
yeah it sounds like the plastic piece inside broke, mine broke right in the middle so it wouldnt even try to go up or down, the replacement part for it was 47.79. i just replaced it two days ago, so if you need help doing it, i can explain it while its still fresh in my mind.
Enthusiast ![]() Joined May 20, '06 From williamsburg, va Currently Offline Reputation: 2 (100%) ![]() |
QUOTE(Stu37363 @ May 19, 2006 - 3:09 PM) [snapback]435789[/snapback] yeah it sounds like the plastic piece inside broke, mine broke right in the middle so it wouldnt even try to go up or down, the replacement part for it was 47.79. i just replaced it two days ago, so if you need help doing it, i can explain it while its still fresh in my mind. please do explain i'm having the same problem with mine that you had and i'm going to have to replace it here in the near future. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) ![]() |
![]() The mast itself is metal, but there is a long plastic part that has teeth in it that the motor uses to raise and lower it. Mine was broken in half when I bought the car so it would go up halfway then make this grinding noise.. http://cgi.ebay.com/ebaymotors/Toyota-CELI...sspagenameZWDVW -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
![]() Enthusiast ![]() ![]() Joined Feb 25, '04 From Fairfield, CA Currently Offline Reputation: 0 (0%) ![]() |
I recommend replacing it with an aftermarket antenna. Check my reply on this thread for details. See end of post for part numbers and brands.
Antenna Thread |
![]() Enthusiast ![]() ![]() ![]() Joined Jun 7, '05 From Corvallis, OR Currently Offline Reputation: 0 (0%) ![]() |
My celica is having the exact same problem. It's pissing me off. I have to help it raise and lower the antenna. I'm just planning on replacing it with an S2000 antenna soon.
also my radio gets really bad reception could this be part of the problem or would that be a totally different issue? the antenna is stuck in the up position but i get bad reception and i don't know why yet.
This post has been edited by celicak: May 21, 2006 - 9:54 PM |
If it's getting bad reception in the up position it makes me think that something is disconnected or not grounded properly. Is your stereo after market or is it original? Have you ever worked on your antenna assembly before? I went through some antenna issues myself and when I finally just spent the 40 bucks to install the aftermarket one that I mentioned above it straightened everything out. I don't recommend replacing the mast because it's as costly as my entire new unit and the first time I replaced the mast it still was a little messed up and then it ultimately stopped working again not long after.
it's after market. I just picked the car up about a week or two ago and i don't think the person before me put the aftermarket antenna plug in it. a buddy of mine that i work with told me he had the same problem with his dodge stratus and then he bought an aftermarket plug attachment and it worked fine. also i decided to get the entire aftermarket assembly that you posted on your thread as it costs less than just the mast. thanks.
![]() Enthusiast ![]() ![]() ![]() Joined Apr 19, '06 From Long Island, NY Currently Offline Reputation: 13 (100%) ![]() |
I'm using a black 9" antenna that is always up not motorized. Gets the job done and no more hassle with the oem antenna.
-------------------- '92 Grey Mitsubishi 3000GT SL - Sold
'96 Black Celica ST 25th Anniversary - Sold '99 Black Mitsubishi 3000GT VR-4 - Sold '04 E250 Work Van - Going soon '08 Grey Dodge Charger Work Car - Ordered |
![]() Enthusiast ![]() ![]() ![]() Joined Jun 16, '06 From Plantation, FL Currently Offline Reputation: 0 (0%) ![]() |
Is there a list of antenna's that work/look good on the Celi? I know the s2k swap, but are there any other options?
![]() Enthusiast ![]() ![]() ![]() Joined Mar 15, '06 From Sunnyvale CA Currently Offline Reputation: 0 (0%) ![]() |
I've had this similiar problem. my antenna just makes a noise like its trying to go down but it doesnt move. you cant even push the antenna down, it just stays there. Actually how do you even take out the antenna??? is there a thread or how to do that? maybe i can fix it if i can get into it.
-------------------- ![]() - 180k and still running strong "Yes...yes I do have a myspace..." |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined May 16, '05 From Toronto, Ontario Currently Offline Reputation: 8 (100%) ![]() |
[start shameless plug]
here's a quick fix to your antenna issues: http://www.6gc.net/forums/index.php?showtopic=35815 item #1 [end shameless plug] -------------------- |
![]() Enthusiast ![]() Joined Jun 14, '06 From bainbridge ga Currently Offline Reputation: 2 (100%) ![]() |
i got a replacement mast and lil windup thingy new in the box it says its for 92-96 camary 90-93 celica convertible 90-93 celica hatchback they guy i bought it from said it would work on my 95 vertible celica but i dunno
![]() Enthusiast ![]() ![]() ![]() Joined Feb 25, '03 From Springfield, MO Currently Offline Reputation: 1 (100%) ![]() |
i bought an autoloc hidden anteanea for $45. unplug the stocker. plug in the hidden, it has double stick adheisive on it so stick on on your back glass on the top where no one can see it. remove hte plastic trim on the hatch, tuck the wire and viola
-------------------- Coming in 2010 full paintjob - new wheels - modified body - new interior - engine build- marriage |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 6, '05 From PA Currently Offline Reputation: 4 (100%) ![]() |
My aftermarket power antenna was like $30
Lo-Fi Version | Time is now: February 22nd, 2025 - 2:43 PM |
