> best way to cut plastic
post May 21, 2006 - 10:29 PM
bloodrain
Joined Mar 3, '05
From Hollywood, FL
well I need to cut some plastic, I want to test out something and write my name in cursive in the plastic. What would be the easiest way to give it a nice clean look. Oh, and the pastic is about as hard as the door stops on our car.
To live, is to suffer
post May 21, 2006 - 10:33 PM
devilsden97
Joined Jun 13, '05
From Poughkeepsie, NY
i was gonna say dremel tool....but the door stops are more rubbery then plastic.
if its hard/ridged, a dremel tool would work best.
if its rubbery...idk
Kawi Love
post May 22, 2006 - 5:28 AM
vsideboy
Joined Mar 29, '06
From Hull, UK
You could try a knife attachment on a soldering iron?
How thick is the plastic mate?
Might be worth looking for a company that would laser cut it for you, then it would be a perfect finish.
post May 22, 2006 - 6:55 AM
Cutrara
Joined May 6, '05
From PA
Scroll Saw
post May 22, 2006 - 8:53 AM
bloodrain
Joined Mar 3, '05
From Hollywood, FL
the plastic is about 1/10th an inch think, the only reason I dont wanna use a dremel is because it will melt and cut the plastic and give an unsmooth finish. I was hopin there was a special knife or somethin used for cutting plastic.
post May 22, 2006 - 8:57 AM
94wrc
Joined Mar 24, '06
From Slough,Berkshire,UK
Maybe if you use some sort of scalpal (?SP?) or craft knife.
Nathan
1994 JDM ST205 WRC with 17" OZ Chrono's wearing 215/45/17 Eagle F1's. HKS Induction Kit, Blitz DV, Decat and full SS System, Blitz SBC-iD and Power Meter running at 1.12Bar = 17mpg and a lot of fun
post May 22, 2006 - 8:58 AM
vsideboy
Joined Mar 29, '06
From Hull, UK
You could use a dremmel to remove most of the material and then use your soldering iron knife to slightly melt the cut rough edge into a smooth edge if sanding is too difficult.
Not sure how you could do it, but a hot piece of wire might cut a nice edge? Maybe pass a current through a piece of fuse wire and see if it does anything? Thats only a maybe, don't go electrocuting yourself dude.
post May 22, 2006 - 9:07 AM
vsideboy
Joined Mar 29, '06
From Hull, UK
QUOTE(94wrc @ May 22, 2006 - 2:57 PM) [snapback]436585[/snapback]
Nathan
Doubt that would work mate, it sounds about 2 - 3mm thick so it would be very difficult to cut with a knife, unless he can use a blowtorch or something to heat the blade?
Lo-Fi Version Time is now: December 1st, 2024 - 11:40 PM
