> Does "performance" flywheels save on gas 4 realz or not?
post May 24, 2006 - 4:47 PM
JediFonger
Joined Oct 2, '05
From Boston, MA
heard from my friend that when i change my clutch (manual) i should also change my flywheel. does a "performance" flywheel save gas? what's the diff between a regular flywheel and a performance one?
post May 24, 2006 - 4:53 PM
CelicaGT04
Joined Nov 22, '05
From Mesquite, Texas
Difference in stock flywheel and "performance" flywheel is weight. Im not sure if it will help you save on gas. But i can tell you that a lightweight flywheel will rev faster thus accelerating faster.
Heres something i found on it to conclude my statement..
CLICK CLICK CLICK
post May 24, 2006 - 5:05 PM
jcbass7
Joined Apr 20, '06
From Florida
that was a great article
post May 24, 2006 - 5:06 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
post May 24, 2006 - 10:57 PM
JediFonger
Joined Oct 2, '05
From Boston, MA
so which is it? i can't really decide. lemme know, might swap out that flywheel s00n as clutch goes.
post May 24, 2006 - 11:16 PM
I'd say yes and no. Yes as in less mass to turn. No because once the flywheel is turning inertia helps keeping it turned.
No matter what saving gas isnt a reason to get one. You'll never notice a difference.
post May 25, 2006 - 12:59 AM
CelicaGT04
Joined Nov 22, '05
QUOTE(JediFonger @ May 24, 2006 - 10:57 PM) [snapback]437668[/snapback]
I personally would not waste my money on a lightweight flywheel for the 5sfe.
(which i have currently) But that is just my opinion.
Then again if i had a 3sgte (hopefully coming this summer) i would definately
try to squeeze any ounce of power i can get thus getting a flywheel. I think you
should just swap your clutch and let it be that. Unless your flywheel gets jacked
while your changing the clucth, then go ahead and get a flywheel! Best of luck!
This post has been edited by CelicaGT04: May 25, 2006 - 1:01 AM
post May 25, 2006 - 1:34 PM
JediFonger
Joined Oct 2, '05
From Boston, MA
what do you mean "gets jacked"? i'm a n00b. just got it last may. that's when i first learned stick as well. do you mean a grinding-type noise when i shift? i always attribute that to my foot not synchronizing well w/my hand. a coordination factor.
so if i did have to swap out the flywheel, just go with regular and nothing special right? ok, thanks.
post May 25, 2006 - 2:54 PM
CelicaGT04
Joined Nov 22, '05
QUOTE(JediFonger @ May 25, 2006 - 1:34 PM) [snapback]437899[/snapback]
Im not quite sure how many ways a flywheel can go bad other than rusting, possibly breaking, or some teeth being torn off.. By that i mean by the teeth being torn off or something of that matter.
Lo-Fi Version Time is now: February 17th, 2025 - 1:41 PM
