4wd conversion |
4wd conversion |
Jun 10, 2003 - 11:20 PM |
Enthusiast Joined Mar 25, '03 From Montreal Currently Offline Reputation: 0 (0%) |
I would like to know where i can find the rear end and drive shaft,etc.. to convert my 95 gt (3s-gte) fwd to 4wd.I search around my place and ebay nothing.thanks!
Jun 10, 2003 - 11:43 PM |
Enthusiast Joined May 5, '03 From Toronto Currently Offline Reputation: 3 (100%) |
Try www.toysport.comToySport
Jun 11, 2003 - 1:14 AM |
Enthusiast Joined Aug 30, '02 From Anaheim, CA Currently Offline Reputation: 0 (0%) |
or buy a rear gt4 clip
-------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
Jun 11, 2003 - 11:40 AM |
Enthusiast Joined May 1, '03 From Michigan Currently Offline Reputation: 0 (0%) |
I have the center drive shaft, and diff carrier from the ST205 available. $50 + shipping.
I also have the rear diff from my ST185 (I swapped in the 205). Its identical to the 205 but does not have limited slip. $75 The gas tank from the alltrac will fit with a custom bracket. This post has been edited by scothaniel: Jun 11, 2003 - 11:40 AM -------------------- Scott
West Michigan |
Jun 12, 2003 - 8:07 AM |
Enthusiast Joined Aug 29, '02 From Lake Orion, MI Currently Offline Reputation: 6 (100%) |
Actually don't call EL, I've heard two of my close buds on celica.net get the shaft from them, One had their harness sent from EL to me to do, and then Ray's celica is still stuck there unfinished after MONTHS.
The AWD conversion is a hell of a lot easier than everyone thinks. but you need a whole GT4 rear end to do it. Any legitimate collision shop has the ability to replace large portions of subframe, and all you do is cut out the trunk pans and swap them, using the wheel wells as a guide on the back, then lickety split you rebuild the car. This take about 30+ hours of labor so be ready to lube up bend over and wait for penetration. My GT-FOUR should be done by the end of summer -------------------- -Mike
mjcoury@gmail.com Team Reynolds Style Celica Blog Celica Wiki It will take him a moment to realize that he's about to make a 180 degree turn at speed, but you will be ready for it. Brace for the g's, and fast heel-toe work. |
Lo-Fi Version | Time is now: November 25th, 2024 - 11:31 AM |
