Enthusiast ![]() ![]() Joined Apr 7, '04 From Toronto Currently Offline Reputation: 3 (100%) ![]() |
Hi guys I was wondering if anybody can help me
by telling me how to install a supra pump. I've tried searching but I cant find anything. Please Help !!!!!!!! |
its not too hard at all.
follow the procedure on celicatech in the BGB on how to remove the fuel pump. its under the back seats...there is an acsess panel, youll remove that, then disconnect the fuel lines. MAKE SURE YOU USE FLARE WRENCHS. trust me, you DO NOT want to strip that connection. take off the cover and pull the pump assy. then swap out the pump. -------------------- Former Team 5SFTE pro member ;)
follow the procedure on celicatech in the BGB on how to remove the fuel pump. its under the back seats...there is an acsess panel, youll remove that, then disconnect the fuel lines. MAKE SURE YOU USE FLARE WRENCHS. trust me, you DO NOT want to strip that connection. take off the cover and pull the pump assy. then swap out the pump. ![]() ![]() -------------------- Former Team 5SFTE pro member ;)
THANKS Pressure !!!!!
just use zip tie to hold it ha. sounds good. Thanks again |
Lo-Fi Version | Time is now: February 23rd, 2025 - 12:40 PM |
