> AC, code help
post Jun 11, 2006 - 4:14 PM
snapshotgt
Joined Oct 12, '05
From Texas
Okay, today my AC light started flashing "flash/pause/flash" etc...and the AC went warm. I turned it off, then back on and it blew cool. I was just wondering what this flashing/AC not blowing cold means...BUT, then i turned it off/on, and it works again?
post please if you know anything!
thanks,
snapshotgt
post Jun 11, 2006 - 4:21 PM
netrata
Joined Feb 16, '06
From Maui, Hawaii
It could be a connector harness that relates to your a/c system. Just check to see if any of the connectors are loose. Try even checking the on/off button harness if its loose.
post Jun 11, 2006 - 5:08 PM
it could be a few things.
first check to make sure your AC amplifier is pluggen in properly. It is located under the pass side of the dash. Just look up from where the pass feet go and make sure everything is plugged in securly.
post Jun 11, 2006 - 5:29 PM
snapshotgt
Joined Oct 12, '05
From Texas
QUOTE(Batman722 @ Jun 11, 2006 - 5:08 PM) [snapback]443678[/snapback]
Alright, i'll go check that out right now....
~snap
post Jun 11, 2006 - 5:43 PM
snapshotgt
Joined Oct 12, '05
From Texas
QUOTE(snapshotgt @ Jun 11, 2006 - 5:29 PM) [snapback]443687[/snapback]
~snap
Everything seems to be good...i mean i was only able to see/reach like 5 connectors...
~snap
post Jun 11, 2006 - 7:05 PM
netrata
Joined Feb 16, '06
From Maui, Hawaii
After checking all the harnesses, are you still having trouble with the a/c going on and off?
post Jun 11, 2006 - 7:16 PM
snapshotgt
Joined Oct 12, '05
From Texas
QUOTE(netrata @ Jun 11, 2006 - 7:05 PM) [snapback]443717[/snapback]
I did nothing but check the harnesses (they were fine), so no, it is not fixed yet.
~snap
post Jun 20, 2006 - 5:14 PM
djkurious
Joined Sep 9, '05
From Nashville, TN
Your compressor needs a new clutch. Just replace the compressor and clutch together. Same thing happened to me.
post Jun 21, 2006 - 2:43 PM
snapshotgt
Joined Oct 12, '05
From Texas
QUOTE(djkurious @ Jun 20, 2006 - 5:14 PM) [snapback]446853[/snapback]
It seems to be working fine now...huh...
anyway, how much did that cost you?
-snap
post Jun 23, 2006 - 6:57 PM
djkurious
Joined Sep 9, '05
From Nashville, TN
QUOTE(snapshotgt @ Jun 21, 2006 - 2:43 PM) [snapback]447233[/snapback]
-snap
I purchased a new compressor with the clutch for $100 on ebay.
Lo-Fi Version Time is now: February 21st, 2025 - 8:35 AM
