caliper ovauhaling, I think I got a bad working one |
Jun 22, 2006 - 10:50 AM |
Enthusiast Joined Feb 18, '06 From NB, Canada Currently Offline Reputation: 12 (100%) |
Ok, my rear left caliper's slider don't seem to be working..the wheel stop at the slightess touch of the brake pedal but the outside of the rotor doesn't look "shiny", as if only the inner pad is applying force. Is it a big job to dismantle the sliders and lube the thing up? What the proper technique ?
This post has been edited by Rayme: Jun 22, 2006 - 10:54 AM -------------------- -Rémy 02 SiR, 08 250R |
Jun 22, 2006 - 11:10 AM |
Enthusiast Joined Dec 28, '05 From Norway Currently Offline Reputation: 0 (0%) |
A caliper overhaul isn't hard, but make sure you get a caliper overhaul kit with
gommets and all the parts. Won't take long to overhaul one. -------------------- |
Jun 22, 2006 - 3:34 PM |
Enthusiast Joined Apr 20, '06 From Florida Currently Offline Reputation: 44 (100%) |
this is something i need to definatly do as well, where can you buy the overhaul kits?
Jun 23, 2006 - 10:06 AM |
QUOTE where can you buy the overhaul kits? At a Toyota dealer -------------------- |
Jun 23, 2006 - 2:15 PM |
Enthusiast Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) |
When u say slider do you mean the rubber pieces that attaches to the brackets and holds the caliper on, or do you mean the caliper piston it self?
If its just the rubber parts you can buy new ones at any auto part store. Its usually the caliper bolts and pins and a caliper bushing kit should be no more than 20-25$ Plus you will need some High temp grease 13$ for a bottle very expensive stuff. Any more PM |
Jun 23, 2006 - 5:46 PM |
QUOTE(soulshadow @ Jun 23, 2006 - 4:15 PM) [snapback]448121[/snapback] When u say slider do you mean the rubber pieces that attaches to the brackets and holds the caliper on, or do you mean the caliper piston it self? If its just the rubber parts you can buy new ones at any auto part store. Its usually the caliper bolts and pins and a caliper bushing kit should be no more than 20-25$ Plus you will need some High temp grease 13$ for a bottle very expensive stuff. Any more PM I would be talking about the caliper pins and bolts and bushing, the piston works -------------------- -Rémy 02 SiR, 08 250R |
Jun 23, 2006 - 8:09 PM |
IF its just the pins and bolts buy new ones and tap out the old ones. If they are super rusted on you will need to hammer them out being careful not to break the bracket. Then once out you have to take a sander or something and clean the insides of the bolt / pin holes to remove buildups. Once done tap the new sliders into place and grease the end of the caliper bolt and stick it in. It should be like new now. Use only High temp grease.
Lo-Fi Version | Time is now: November 27th, 2024 - 6:58 PM |
