> FS: Built JDM 3S engine/turbo setup, T3/T04E, AEM ECU,Car included. Now with pics!
post Jun 25, 2006 - 11:51 PM
JGS3SGE
Joined Dec 4, '04
From Oregon
The story- This is an old project of mine orginally built to be a test car for the products I make.
We've moved on to other fields since construction.
The skinny-
-2nd gen 160HP 3SGE
Mods-
Completely rebuilt with OEM parts including oil pump, water pump, belts, bearings, TTE headgasket.
Head- 3 angle valve job, shim adjustment, full port/polish, matched.
Bottom end- 8.8:1 Wiseco pistons/rings/locks, Eagle rods, 3SGTE oil sqirters, brand new OEM crank, ARP studs
Intake mani- MA70 60mm TB, 4 additional injectors under the mani, Factory dual plenum setup
500 break-in miles since build
-Turbo system
.50 trim T3/T04E .63A/R stg. 3 turbine, blacked out FMIC, 3SGTE mani with adapter, 2.5 DP, 3" exhaust, JGS 40mm WG, WG dump, JGS bypass valve.
-Engine managment
AEM SW20 ECU, stock 310cc injectors, 460cc secondary injectors, Aeromotive regulator, TTsupra fuel pump, Autometer gauges (fuel pressure, oil pressure, AFR,boost), AEM WB02, PS92 crane coil, magnacore wires,
Mallory fuel billet fuel filter, braided 6an fuel lines.
-Drive train
97 S series trans with 3SGTE clutch, Heavy duty E series 98+ Camary trans included
Points of interest-
Cruise control works, A/C is there and should work with a good charge, manual locks and windows. Susp. Tech sway bars, Eibach springs, GT rear disc brakes, braided brake lines (not installed).
Negatives-
Roof dented do to hood accident, air bags need replaced from old accident (no major unibody damage, airbags included), hood is black (again accident), minor dents and scratches on the front fenders. Needs TLC.
Would make a good base for a weekend racer as it was orginally an ST/Base so its very light. OR could be stripped to be installed in any celica and the car could be parted/scrapped...
Its runs and drives in its current state, has commuter tires on 5th gen wheels.
I will do current pics for SERIOUS buyers.
Looking for $5000, thats about 50% the cost of the drivetrain alone (like I said car included free).
My lack of time is your gain.
Some of the older member here, if their still here may remember this car.
BTW- its a blue 94 hatch
This post has been edited by JGS3SGE: Jun 27, 2006 - 1:01 AM
post Jun 27, 2006 - 1:05 AM
JGS3SGE
Joined Dec 4, '04
From Oregon
Forgive the dirt and cobbwebs...
Lo-Fi Version Time is now: November 27th, 2024 - 2:52 AM
