![]() Enthusiast ![]() ![]() Joined May 25, '06 From South Carolina Currently Offline Reputation: 3 (100%) ![]() |
ah! someone gave me a gift, a shift light
http://www.cardomain.com/item/ATM5332 and...it takes some rpm module or a huge flippin tach to make it work? is that right? so another 80 bucks for a module? i thought it was going to have a few wires, i would connect some power...some ground and one to the tach...and it came with a end that needed to plug into somthing...can anyone point me in the right direction? thanks -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() Joined Dec 3, '03 From Cyprus Currently Offline Reputation: 0 (0%) ![]() |
you can connect it directly to ecu. with 3 wires ..power, ground. and ignition rpm wires.. but you need you cars ecu wiring diagram. do you have a cataloge of your shift light?
if not tell me to send you -------------------- ![]() |
i dont, please send. thanks
so you saying i should cut off the female end of the shift light and it should have 3 wires i can run to those 3 things? thanks for help -------------------- ![]() |
QUOTE(Griff @ Jul 24, 2006 - 4:52 AM) [snapback]460015[/snapback] i dont, please send. thanks so you saying i should cut off the female end of the shift light and it should have 3 wires i can run to those 3 things? thanks for help here is wiring or 3sge for şhift light ![]() This post has been edited by tufy: Jul 24, 2006 - 7:00 AM -------------------- ![]() |
Lo-Fi Version | Time is now: February 23rd, 2025 - 8:38 PM |
