> 7A intake new bling doesn't work, 94 and 97 chamber covers won't easily interchange
post Aug 20, 2006 - 10:20 AM
97lestyousay
Joined Jul 7, '03
I have a polished intake for a 7a but it is 94-95. Everything appears to
be the same as far as bolt pattern and hose connections go. The basic shape
is different. I was just wondering if they will interchange.
This post has been edited by 97lestyousay: Mar 19, 2007 - 6:23 PM
JDM guy made me do it.
post Aug 21, 2006 - 2:42 PM
nik
Joined Sep 30, '02
QUOTE(97lestyousay @ Aug 20, 2006 - 8:20 AM) [snapback]470822[/snapback]
they should be the corolla 7afe intake looks different than the 7afe 94,95
post Nov 19, 2006 - 5:04 PM
97lestyousay
Joined Jul 7, '03
post Nov 19, 2006 - 5:07 PM
that looks SWEET man! good work!!
post Nov 20, 2006 - 3:03 AM
that looks incredible Randy, purely incredible. WOW !!!!
post Nov 20, 2006 - 10:40 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
that does look sweet. +3 i like it.
post Nov 21, 2006 - 11:40 PM
normality78
Joined Oct 27, '05
great one...
post Nov 22, 2006 - 11:36 AM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
looks good Randy, but nobody answered your question lol
I'd say if the bolt holes line up it would be fine, can't hurt to try I guess smile.gif
I <3 Dustin---07/16/06
post Nov 22, 2006 - 11:40 AM
Culpable04
Joined Apr 17, '06
From New Jersey
should be ok !
but if it's not pass it dowm to me biggrin.gif will be in good hands
ps I'm serius about that, if it doens't fit let me know and I'll get it from you, I have a back pack full of pennies smile.gif
post Mar 19, 2007 - 6:14 PM
97lestyousay
Joined Jul 7, '03
It looks good but don't work. Everything lines up all hoses connect.
The underside is different the pcv inlet is in a different spot, and the housing
itself is quite a bit different. Upon startup it revs to, I assume the limiter
I shut it off before it hit 5000 but it was rapidly increasing, not quite WOT
but close. I had my son check the throttle body and it never opened he said.
so its pulling air from somewhere. I never threw a code at all. I tried it about
6 times removing the cover 3 times to check stuff with no luck. I put the 97
back on and it ran perfect no problems at all. The 94 manifold chamber is
evidently quite a bit different than a 97. Anyone have any Ideas?
post Mar 19, 2007 - 7:50 PM
97lestyousay
Joined Jul 7, '03
Heres the problem. The port below isn't covered by anything other than the metal gasket,
on the 94 manifold that area is totally open and the gasket isn't held down by anything.
Learn from my stupidity and don't try this.
post Mar 19, 2007 - 8:46 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
what is that port for? where does it go to?
you can't just cover it up with something?
post Mar 19, 2007 - 8:51 PM
94st_santos
Joined Oct 3, '05
From Houston, Texas
yeah when I took my intake off mine would rev too, but it was because I left one of the bolts off from the egr valve.
Oh yeah I was looking at the inside of your intake manifold and it looks different than mine.
This post has been edited by 94st_santos: Mar 19, 2007 - 8:54 PM
post Mar 19, 2007 - 9:00 PM
Culpable04
Joined Apr 17, '06
From New Jersey
QUOTE(Culpable04 @ Nov 22, 2006 - 11:40 AM) [snapback]504507[/snapback]
should be ok !
It's sad that it doesn't fit on yours after the effort you made for it. if you don't have a solution, I would take it from your hands.
post Mar 19, 2007 - 9:06 PM
97lestyousay
Joined Jul 7, '03
QUOTE(hurley97 @ Mar 19, 2007 - 6:46 PM) [snapback]537833[/snapback]
It has dry carbon in it so the air in it has exposed to combustion,
the 97 intake blocks it so blocking it at the port would probably fix
it. I am just going to forget about it and maybe polish the 97 and
engrave it or just forget the whole altogether since I plan to swap
post Mar 19, 2007 - 9:09 PM
97lestyousay
Joined Jul 7, '03
QUOTE(Culpable04 @ Mar 19, 2007 - 7:00 PM) [snapback]537843[/snapback]
should be ok !
The manifold in your profile pic looks the same as my 97, is that the original motor?
I figured it would be the same the polished 94 I have.
post Mar 19, 2007 - 9:27 PM
Culpable04
Joined Apr 17, '06
From New Jersey
it was my original motor kindasad.gif I replaced that one with a 95 engine same year but stupid me didn't swap the red cover so now my engine bay doesn't look as clean kindasad.gif
post Mar 19, 2007 - 9:37 PM
QUOTE(97lestyousay @ Mar 19, 2007 - 10:09 PM) [snapback]537848[/snapback]
you are right Randy, he has a 96+ intake mani cover on that *
* Stevenson, you said the motor was replaced with another 95, correct ? I would guess it was a 7a from a Corolla, not a Celica wink.gif hence the different intake mani cover (same year)
post Mar 19, 2007 - 9:42 PM
Culpable04
Joined Apr 17, '06
From New Jersey
QUOTE(Batman722 @ Mar 19, 2007 - 9:37 PM) [snapback]537862[/snapback]
I'll take a look at my current manifold tomorrow morning and compare it to the pic here. but my guess is that the engine is from a corolla and that would explain why I don't have a sample port for the EGR temp sensor. kindasad.gif
I'll get rid of the whole EGR set-up as soon as I get my hands on a multimeter smile.gif
This post has been edited by Culpable04: Mar 19, 2007 - 9:43 PM
post Mar 20, 2007 - 11:38 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Randy, whenever you decide to swap, let me know. I would take that intake manifold cover and the valve cover off your hands, and if you are going to try the swap yourself, I might be able to get over there and help out a bit. smile.gif
**** Photobucket
Lo-Fi Version Time is now: November 27th, 2024 - 2:38 AM
