> what 3sgte should i get
post Aug 21, 2006 - 2:22 PM
6G94celica
Joined Jan 22, '06
From Savannah, GA
ok so yea i feel pretty much like an idiot because when i bought my car i was told it was a GT. as i did more research i looked into the engine and i even looked on the hood and it said it was a 2.2L 5sfe. well that hood must have been replaced because my car is for sure an ST. i have decided to go to a 3sgte engine but am not sure what one i should swap in. i want alot of power. should i go with the clip out of the Caldina, Mr2, or Celica all-trac. the caldina would be the most power but is it all the same to put in or are some more feasible than the others to put in.but like i said i wouldnt want any of the 3sgte engines to be under 225 horses stock. but if you could all help me out that'd be great thanks.
post Aug 21, 2006 - 2:34 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
since you have an ST you are going to need GT motor mounts, gt shift cables, gt powersteering and gt ac lines (provided you want to keep that stuff) PLUS the clip.
id suggest alltrac clip, mr2 requires you to move the alternator and maybe something else im not sure, and caldina will jsut be hard to find and expensive and harder to swap.
post Aug 21, 2006 - 11:35 PM
burneeed
Joined Dec 18, '05
From BANNED
^^ Lol clip comes with that.... whats the point of the clip if it didnt come with motor mounts and trans mounts... what do you think is holding up the motor in the clip...
so anywho...
depends on what you want to do like what your goals are power wise. the second gen has tons of aftermarket support here n america. If your looking for something to drop in and modify in the future for the price of a clip they go for around 2k now. and thats a full alltrac/gt4 there also 225hp.
If your looking for something to go ahead drop in and never touch again and make good reliable power a st205 clip/gt4 clip is for you. Its 255hp with a w2a intercooler. its a great engine its a little more expensive than a 2nd gen clip. But its much worth it if you have the money. It already comes with a better intercooler better turbo and It has a multy steal headgasket with 550cc injectors and one awesome turbo. Its a great motor for just small bolt ons.
Now to the transmission part. You will ethier need a celica gt trans. or a E153 trans out of a Mr2/v6 solara / v6 camry. Its easier to just get the solara or camry trans being that they are already setup for fwd. get that trans you have the mounts and the crossmember to work from the st205 clip and go to town ! heh.... and you will have yourself a pretty cool car biggrin.gif.
BANNED!
post Aug 21, 2006 - 11:41 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
QUOTE(burneeed @ Aug 22, 2006 - 4:35 AM) [snapback]471475[/snapback]
not on the clip i suggested.
post Aug 21, 2006 - 11:56 PM
burneeed
Joined Dec 18, '05
From BANNED
what clip are you talking about? Clip is a clip they all come with the mounts....... 2nd gen or 3rd gen S block mounts are S block also... E153 mounts are E153 mounts.... both will work on any e153 out of a solara/camry/mr2 ... and that one motor mount will work also.
This post has been edited by burneeed: Aug 21, 2006 - 11:57 PM
BANNED!
post Aug 22, 2006 - 12:12 AM
tin_foil
Joined Jun 7, '05
From Corvallis, OR
post Aug 23, 2006 - 11:56 AM
babysupragt
Joined Jun 24, '06
From Houston.TX
if i was you i will get da st205 3sgte with da E-153 mr2 turbo tranny
This post has been edited by babysupragt: Aug 23, 2006 - 12:07 PM
post Aug 23, 2006 - 12:10 PM
QUOTE(burneeed @ Aug 22, 2006 - 12:56 AM) [snapback]471482[/snapback]
hes talking about the st185 clip . since its a 5th gen, their motor mounts dont work in our cars.
post Aug 23, 2006 - 12:24 PM
Kadett
Joined Mar 17, '05
From The Netherlands
QUOTE(burneeed @ Aug 22, 2006 - 6:35 AM) [snapback]471475[/snapback]
Agree with this 100%
And with BPU you wont loose anything of the reliability and get about 20-30 hp gain.
Plus its about 90% direct plug and play dont have to have major headaches about rewiring.
This post has been edited by Kadett: Aug 23, 2006 - 12:26 PM
post Aug 23, 2006 - 1:00 PM
please post in the appropriate forum.
this is a forced induction motor, so it should be in FI.
post Aug 23, 2006 - 6:27 PM
6G94celica
Joined Jan 22, '06
From Savannah, GA
hety sorry about the wrong topic thing man but anyways, so you are all basically saying if i want to get an engine to modify and upgrade, because im not just gonna leave it im going to keep adding stuff on, but i should get the Mr2 or the alltrac 5th gen
post Aug 24, 2006 - 1:00 AM
burneeed
Joined Dec 18, '05
From BANNED
QUOTE(lagos @ Aug 23, 2006 - 12:10 PM) [snapback]472008[/snapback]
QUOTE(6G94celica @ Aug 23, 2006 - 6:27 PM) [snapback]472162[/snapback]
do not buy the mr2 clip... get a alltrac/st185/90-93 gt4 clip... all the same terminology.
This post has been edited by burneeed: Aug 24, 2006 - 12:58 AM
BANNED!
post Aug 24, 2006 - 11:39 AM
Rjb23
Joined Feb 8, '04
From KY
ST185 mounts will not work!! They are completely different. Just spend the $200 and get all the GT mounts it will save you headaches.
post Aug 24, 2006 - 11:51 AM
isn't punisher using ST185 modified mounts
post Aug 24, 2006 - 1:39 PM
burneeed
Joined Dec 18, '05
From BANNED
QUOTE(playr158 @ Aug 24, 2006 - 11:51 AM) [snapback]472392[/snapback]
Like I said just a little bit of modification and they will work....
200 dollars for a motor mount are you nuts?
BANNED!
post Aug 29, 2006 - 6:55 PM
6G94celica
Joined Jan 22, '06
From Savannah, GA
ok so then the mounts that come with the alltrac 90-93 will work. what kind of modifications are necesarry. one more question is does anyone know if there is a mechanic familiar with this kind of stuff in the western wisconsin area. or are any of you from around here and interested in helping me with this swap.
post Sep 3, 2006 - 9:15 AM
JaxMadine
Joined Jan 31, '06
I am in the middle of a swap for my cheap friend, and the 5th gen mounts will not work unless u do a bit of sheet metal fabrication. It is a huge headache and not worth the time to try and get those mounts to work. Just buy the GT mounts.
post Sep 12, 2006 - 4:55 PM
6G94celica
Joined Jan 22, '06
From Savannah, GA
so then where do i go to buy the gt motor mounts or can i just go to a junk yard with a 6th gen gt and get the mounts off that
post Sep 12, 2006 - 5:20 PM
get new ones don't get junkyard crap
search online..there are thousands of places or go to your dealership
post Sep 13, 2006 - 3:03 AM
Symbiote5S-FE
Joined Dec 9, '05
From Calexico CA
kindasad.gif can you make an st185 like an st205....what i mean by that is that could you make the 2nd gen as fast as the 3rd gen by applying a better turbo and other parts? kindasad.gif i just want to make sure about that cause i am also thinking of buying one. biggrin.gif
5 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: February 20th, 2025 - 3:19 PM
