5 Pages V   1 2 3 > »
> The V6 Celica is here, sharing my experience
post Aug 28, 2006 - 6:18 PM
K-ESD
Joined May 5, '05
From New-Brunswick Canada
For those who have not been reading.
The V6 swap has been done
This project started in october 2005 when I finaly narrowed down what I wanted for the Celica.
My options were either the famous relatively easy 3rd gen 3SGTE swap or the blind path of the V6.
Before I begin, I owe a big thanks to all the MR2OC guys that helped me out. I was maybe alone in the garage but I had their support at all time. Big thanks to Adrian (aka: SbCelica on MR2OC). He pioneered the FIRST V6 Celica, a 5th gen celica with a 1MZFE. He was who inspired me to start the project. I followed in his foot steps.
Research took from october to april and even continued on as I made my progress. I spent a good two months gathering parts and getting everything ready for the big swap. Often reading myself to sleeping with a pile of toyota wiring diagrams in my bed.
Here's how I made it happen
My setup:
04 Sienna 3MZFE
-150amp Alternator
-Solara power steering (sienna pump doesn't fit)
-Toyota Matrix K&N intake (thats right, a Matrix intake fits)
-Fidanza 1MZFE Flywheel
-3SGTE clutch
01 Solara E153 Transmission
-Alltrac rear and driver side mount, GT front mount
-GT-FOUR shifter cables
-MR2 turbo (non LSD) inner axles
-Solara axle carrier
-ST185 outter axles (with abs cause I have it)
-ST185 speed sensor
I don't know where to start, to me it's all self explainatory. Without going into deep details, heres a few pointers.
The engine fits very well inside the engine bay, no clearance issue at all. It's narrower than the 5SFE and less in a slant so the rear is easily accessed. It fits better than a 5SFE basicly.
The hood is a minor issue, it closes just fine but it's so close it's scary. The whole front bank (head) touches the insulation of the hood. The cure is a GT-four hood and we all know it needs a GT-four bumper aswell. I have that up on the upgrade list. smile.gif
Wiring isn't hard ! You all get that out of your head
It's very time consuming tho, preparation was the key. On paper it took me months to prepare it bit per bit but it took me about 10 hours to physicaly do it. Keep in mind that this is for the most electronicly advanced V6 swap (next to the still unexploited 2GRFE). The ECU controls the automatic transmission so it needs to be fooled into thinking there is one by putting resistors where it seeks the transmission coils. I haven't got around to perfecting that.
This engine uses a returnless fuel system, basicly a ordinary fuel pump with the regulator inside the tank. I adapted this system by swaping out my 5SFE pump for a sienna pump (bolt on, plug and play), hacked off a section off the steel return line next to the pump, strapped on the regulator and Tee-d the main line to the return line on top of the fuel pump cap.
Gas pedal, no longer. It's now a accelerator position sensor. AKA drive by wire. no more throttle cable, no more cruize control servo and computer. it's fully electronicly controlled by the ECU now.
Immobilizer - I have two keys now, one for my ignition and one with a chip in it to satisfy my immobilizer so it'll let me start my engine. I had to get the coil amplifer (basicly the ring around the ignition) and the immobilizer computer ("immobilizer" is an annoying word to type)
Mounts, those are a piece of cake. 3 mounts are on the transmission, I swapped out for a E153 Solara V6 transmission. More on that later. I used alltrac rear and driver side mounts. The rear had to have a spacer because the cross member had a slant in it and the mount would have sat on an angle. The driver side had to be grinded down a bit to fit because it was too large to fit in the frame bracket. The front is my old GT stock.
The passenger side one had to be custom made, I simply took out the mounting bracket and made one that fit for the V6. Personaly I don't like this but it works and doesn't seem to cause any problems. I will be making a whole new mount for it using a spare driver side mount.
The stock strut bar fits but interferes with the engine rocking back and forth so I took it out and will be making a custom strut bar. I didn't notice any change in handling.
Transmission, as I said before, I am using a 01 Solara E-153. I had to get a speed sensor, shifter cable mounting bracket and levers (thank you bigal wink.gif). I was under the impression that the alltrac cables would fit but they do not fit and are not even close to fitting. So I bought some GT-four cables, they snap into place and work like a charm.
Axles, I used non-lsd mr2 turbo inner axles (because I don't have LSD) ST185 outer ABS axles (because I have ABS) and a Solara V6 axle carrier. Fit right into place but I still have to get a spacer for the passenger side axle. it works tho
Exhaust - the nightmare
Nothing fit, not the front nor the rear headers fit. I did a simple cut, flange, route job to my stock exhaust for the moment. At this time I ran out of funds and could not afford a full exhaust. I will be making custom headers for this baby, 2.5" front to back, magnaflow muffler.
Radiator hoses are a mess, the outlet and inlet are at opposite side of the radiator. The overflow tank needs to be Tee'd because I now have two fill caps. One on the engine and one on the rad.
EVAP system, I got a EVAP canister from an Echo and stuck it on the opposite side of the muffler at the rear. Drilled a hole in the fuel tank, just in front of the fuel pump cap and stuck a check fill valve. This isn't necessary unless you want to get rid of the check engine light (and codes). Or live in a place that have strict emission guidelines. anyone from cali?
and more but I can't think of anything else right now.
To this day, even if it runs, I don't concider it complete. I have some bugs to work out and some minor refinements. Towards the end, I was broke and I needed to rush things because I was starting a new job and needed a car so I did the bare minimum. Now I'm too busy working and paying off debts, lol but I'm not giving up. Winter is coming, things will settle and I will perfect it.
I am hoping that the V6 swap becomes mainstream. It's not that hard to do and can be done for less than a 3SGTE. Please don't argue this before researching the prices.
My swap was a full drivetrain swap, it would have been much simpler if I would have stuck with the GT tranny and I would have cost much much less. But the Solara tranny is far better than the GT tranny and is optimal for this engine.... at a price.
There is also the 1MZFE which is easier than the 3MZ, less wiring, less gizmos (no drive by wire, no immobilizer, fewer o2 sensors, etc... just simpler)
Well thats all I want to say for now, I have to take a break from typing so much. Too many PMs to reply too on top of this.
----------------------6GC's FIRST V6----------------------
JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy
post Aug 28, 2006 - 6:21 PM
celica47
Joined Feb 3, '05
From Tampa, Florida
Hey man congrats...your a PIONEER...iam really interested in this swap as many others...iam sure we'll see this as a sticky or in the FI sticky
I'am Reinventing the SLow Lane.....
post Aug 28, 2006 - 6:23 PM
K-ESD
Joined May 5, '05
I must add, the information above is for a 3MZFE
Mounting is the same for all other V6's but alot of the rest is because of the technology of the 3MZFE
post Aug 28, 2006 - 6:31 PM
HaRv3sTeR
Joined Nov 22, '03
From Tracadie-Sheila, NB (Canada)
props Nick!
how that thing is pulling?
94_st_hatchback
Joined Mar 15, '06
From Long Beach
GET SOME VIDS!!!
" i don't work for toyota, i work for my toyota. "
post Aug 28, 2006 - 6:39 PM
coldbluesteel
Joined Jul 9, '04
From Las Vegas USA
Congrats, I want to be the first to use the 5vz! I've got one in my 4runner and it's NICE!
post Aug 28, 2006 - 6:59 PM
WALKER
Joined Mar 29, '06
From Regina, SK, Canada
Good work, glad to hear its working for you!
I will definately hit you up with questions if I decide to go the V6 route. The 2GR-FE is the route I would be taking though!
post Aug 29, 2006 - 10:38 AM
Punch
Joined Jan 29, '04
From Brooklyn moved to Miramar Florida
a vid would be great...
post Aug 29, 2006 - 11:06 AM
PICS!!!!!!!!!!
nice job!
post Aug 29, 2006 - 11:33 AM
hitcachi
Joined Jun 19, '05
From Nebraska
post Aug 29, 2006 - 12:04 PM
jdg371
Joined Jun 14, '05
QUOTE(WALKER @ Aug 28, 2006 - 7:59 PM) [snapback]473887[/snapback]
the 2GRFE is a crazy engine. Basictly its Toyotas answer to the overly used VQ35DE.. which seems to be in every Nissan
When swapping the 2GRFE make sure its enuff power. F/I on those are not recomended. Keeping the original equipment will ensure best result. The engine is built and not much room for improvement.
A more casual setup would be the 1MZFE. if more power is needed TRD supercharger
post Aug 29, 2006 - 2:09 PM
bindertch
Joined Aug 18, '04
From Silverdale, WA
QUOTE(coldbluesteel @ Aug 28, 2006 - 4:39 PM) [snapback]473881[/snapback]
You had better get to work. I have ideas on a few things for this including making it a rear wheel drive with posi. I already have the source engine if I get to do my V8 swap in my truck the celica will be next starting from a GT that I found.
This post has been edited by bindertch: Aug 29, 2006 - 2:10 PM
post Aug 29, 2006 - 2:13 PM
twolownissan2002
Joined Mar 22, '06
From Wesley chapel, Florida
pic would would be nice great work bro
post Aug 29, 2006 - 2:20 PM
WH95TE
Joined Jun 16, '06
From Plantation, FL
Very Very nice, I too want to see pics and videos though biggrin.gif what kind of numbers are you putting out right now? And what are your goals
post Aug 29, 2006 - 5:01 PM
celicurr
Joined Jan 29, '06
From Kitchener, ON, CA
what everyone else said... nice, but we need pics and vids!
post Aug 29, 2006 - 5:21 PM
Shigexile
Joined Oct 30, '03
From IL
so it actually happened...
congrats man congrats.
yes as everybody says.... we want some vids!
post Aug 29, 2006 - 5:49 PM
K-ESD
Joined May 5, '05
It was the biggest project I've ever done in my entire life, I'm very proud of it. It was a long ruff road, lots of cuts, bruizes, blood, stress, money, money, debts, school, girlfriend getting mad at me.
Pictures will come shortly, I only got it on the road a couple weeks ago. As for vids, i'm planning on intergrating a webcam to work with my carPC, so it might be a while. This will all get done when I take it off the road for the winter, probly sooner than winter because I want to get alot of stuff done while it's still somewhat warm. Also I need to gather funds to upgrade my exhaust and get some better parts (new hoses, cv boots, lines, etc...)
All this isn't official, it's just a taste. I will work out the bugs, make replica custom parts needed for the swap and make a highly detailed information guide. My goal is to push the idea of a V6 swap in a celica. I want it to become mainstream as much as the 3SGTE.
also, here is my june picts. I don't have any recent picts unfortunately. (don't own a digicam)
post Aug 29, 2006 - 6:28 PM
illneversellmyce...
Joined Jul 11, '06
From Sefner, FL
Iwant to know the pirce of it all vs the 3g, i want to do a swap next year, but now this has me thinking about this swap lol. Man I'll ahve so much research t odo on here lol
post Aug 29, 2006 - 6:36 PM
6th_celi_vert
Joined Jan 16, '06
From Kentucky
you've inspired me.
Im gonna drop a 454 in mine. lol.
JK, nice work man, cant wait to see pics.
post Aug 29, 2006 - 6:49 PM
LBCxGUY
Joined Jul 6, '03
From Long Beach, CA..."LBC"
just wanted to know ur driving impressions on the v6...a lotta people shot me down loooooong time ago about that swap, but anyways just wanted know how it felt and have u pushed the engine really hard yet.
5 Pages V   1 2 3 > »
Lo-Fi Version Time is now: November 22nd, 2024 - 5:24 PM
