> finished gt4 conversion, azian_advanced
post Sep 4, 2006 - 6:40 AM
azian_advanced
Joined Apr 18, '05
From Calgary
Part A - A How-To
I've finally finished my gt-four front conversion.. to be honest, seeing it in person is a lot more surprising than in the pictures.. this is probably my best mod so far and was far beyond my first expectations..
perhaps i'm overexaggerating a bit but in short, this is definitely hotter than what i had in mind smile.gif .
it was not an easy task for me since my car was previously in an accident and the fenders, hood, and gt-four bumper didn't line up like it should. so washers were added onto bolts to fill gaps to align the fenders properly. but otherwise, you shouldn't have a problem since everything attaches the same way.
i first thought that this was simply ALL BOLT ON but really wasn't. i mean, it was but it wouldn't fit and line up correctly... so a couple of things (for you future gt-four convertors) that needed modifications were:
1. cutting the st205 reinforcement bumper
2. the gap to fill between the bumper and hood
the reinforcement bumper was not a direct bolt-on job... the front frame rails where the re-bar bolts on to is different on the gt4's.
this is how it appears when you have it against the frame rails...
IPB ImageIPB Image
as you can see, the bottom is far too forward for the upper threading to fit through...
this is how it looks after being cut (using an impact metal sheet cutter):
IPB ImageIPB Image
IPB ImageIPB Image
and here it is when bolted on
IPB ImageIPB Image
another thing which i totally missed is when you have the bumper installed, the bar sits slightly higher than it should be. right now, it doesn't fit in the groove on the bumper absorber. that may be because my car was in a previous front end accident and things aren't lining up 100% perfect.
to fill the gap between the bumper and hood, i used about 2.25" screws with a nut. the head of the screw and the nut clamps the bumper seal to the bumper plastic, and the bottom tip of the screw screws into the threading on the metal retainer. thank god i have tons of all sorts of screws in my garage. finding the right screw is gonna be hard. i've heard other members use the same thing but instead used washers to lift the bumper up high. either way is fine i guess, but i like my idea better. this is how mine looks like btw...
some custom 4" lamps were put in. i bought them from a local hardware store for $8 each (which beats the ~$250 that they normally cost). though they don't mount onto the rebar but are just the lamps themselves.. i've read that another member used Mercury Topaz (or something) 4" fogs instead but i couldn't find those anywhere. besides, i like the crystaly (not sure if that's even a word tongue.gif ) look better. they're basically glued to the fog light housings though i'm not sure if the glue will hold because these lamps tend to get pretty hot when on. i don't think i'll be wiring them up anyway...
IPB ImageIPB Image
IPB ImageIPB Image
that's all there is to know for the conversion.. it's relatively simple just takes some time.
in my case, i also had the fenders that came off the clip where my bumper and hood came off of. so i ordered some jdm sidemarkers and wired them up to the turn signals.. this is also an easy mod and very appealing at night.
Part B - Becoming
IPB ImageIPB Image
IPB ImageIPB Image
IPB ImageIPB Image
IPB ImageIPB Image
IPB ImageIPB Image
IPB ImageIPB Image
IPB ImageIPB Image
IPB ImageIPB Image
Part C - Completetion
IPB ImageIPB Image
IPB ImageIPB Image
IPB ImageIPB Image
IPB ImageIPB Image
IPB ImageIPB Image
post Sep 4, 2006 - 6:45 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
This pictures are what I waited for... amazing work! bowdown.gif bowdown.gif bowdown.gif
post Sep 4, 2006 - 6:47 AM
Insanity-74
Joined Jan 9, '05
From Under the car
Nice job.
post Sep 4, 2006 - 7:23 AM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE(azian_advanced @ Sep 4, 2006 - 6:40 AM) [snapback]475993[/snapback]
The rails aren't different and you shouldn't have to cut anything. You just need the right brackets:
Frame Bracket RH 57201-20060
Frame Bracket LH 57202-20070
Also, judging by this picture:
I'd say you need these parts as well:
Seal, hood to front end panel 53395-20020 $19.92 This is the rubber seal where the hood and bumper meet
Retainer, front bumper upper center 52521-20200 $25.44 this is the metal thing that holds the rubber in place
Otherwise I think it looks pretty good.
post Sep 4, 2006 - 7:51 AM
QUOTE(WannabeGT4 @ Sep 4, 2006 - 8:23 AM) [snapback]476001[/snapback]
x2 on the frame brackets..props for creative thinking getting it to work tho, once you get the hood seal and retainer in, it'll look super!
also..anything that says "gt-four" on a car thats not is kinda a pet peeve of mine..but again creative thinking..
post Sep 4, 2006 - 8:34 AM
Celica power
Joined Mar 16, '05
From Netherlands
damm that is a mean looking car
post Sep 4, 2006 - 8:44 AM
twitchh17
Joined May 19, '06
From North NJ
nice job man. the before and after pics are awesome. again, great job. wish i had the money and time to do this myself.
post Sep 4, 2006 - 8:47 AM
malpaso
Joined Feb 3, '06
QUOTE(presure2 @ Sep 4, 2006 - 2:51 PM) [snapback]476005[/snapback]
IMHO... I have also SS-III sticker on my car and it's not SS-III at all (or Beams, TRD, superstrut suspension, etc.) biggrin.gif. Professional will recognise that and amateur don't even care (if it's or it's not GT-four/SS-III)... but everyone see damn good looking car! That's my opinion about this...
post Sep 4, 2006 - 8:50 AM
DSRT-FX
Joined Sep 13, '04
From Sydney/Australia
holy smokes! that is hot!!!!
ROM-23L 67 + 76 = 143
"I wasn't pursuing Sephiroth, I was being summoned by him." - Cloud Strife
post Sep 4, 2006 - 9:23 AM
Jaws4God
Joined Mar 27, '04
awesome! pics are great!! makes me want to switch and do a GT4 conversion tongue.gif
post Sep 4, 2006 - 11:10 AM
kCed
Joined Jul 4, '06
From winnipeg
looks good...i saw it yesterday when you were leaving your work!!!
i was in the green celica...i actually just bought raiser blocks of babycakes on heights!
anyway looks badass
post Sep 4, 2006 - 12:05 PM
azian_advanced
Joined Apr 18, '05
From Calgary
QUOTE(presure2 @ Sep 4, 2006 - 7:51 AM) [snapback]476005[/snapback]
wow.. i didn't even know you can get those frame brackets... always thought they were fixed on the car.
and about the seal and retainer, i just took the one off the old bumper and bent it to fit the new bumper so i can start using it asap.... it's almost a direct swap with different angle bends. but i think i'll buy the gt4 one anyway
post Sep 4, 2006 - 12:26 PM
hitcachi
Joined Jun 19, '05
From Nebraska
QUOTE(malpaso @ Sep 4, 2006 - 8:47 AM) [snapback]476012[/snapback]
most dont care because 90% of the american population doesnt even know what a gt-4 or SS-III celica is. Looks awesome.
post Sep 4, 2006 - 12:42 PM
Sh0gunkid8721
Joined Feb 22, '03
Im just curious...Whats the difference between a base model Civic or Integra putting on a Type R sticker or somethin along that line and a Celica with a GT-4 / SSIII badge on it? Yet the Civic and Integra owners are called ricers but the badging on Celicas, they're considered cool. Everytime i come on this site, i hear stories about a riced out Civic but when the Celica has the same modifications, its considered cool. Im just confused by this. Im NOT ragging on ur car cuz i think it looks nice, but i dont get some of ur peoples train of thought. Wouldnt that be considered hypocricy?
post Sep 4, 2006 - 2:01 PM
j0e_p3t
Joined Dec 8, '05
From torrance/carson, ca
looks sweet. plus another great how-to article. good job. nice pics.
post Sep 4, 2006 - 2:58 PM
Akimbo
Joined Jun 30, '03
From O-town, FL
looks great. its something id love to do..but I dont have that kinda money to be tossing around. I'd even finish it with real 3 spokers.
- Ryan
aim: rkgreen04
post Sep 4, 2006 - 3:29 PM
hitcachi
Joined Jun 19, '05
From Nebraska
QUOTE(Sh0gunkid8721 @ Sep 4, 2006 - 12:42 PM) [snapback]476054[/snapback]
post Sep 4, 2006 - 4:01 PM
azian_advanced
Joined Apr 18, '05
From Calgary
hahah.. nice..
anyway, i've been toying out about putting that gt-four emblem on the upper grill there. i knew i'd get some feedback regarding that. imo, i really like the way it looks with the emblem on, but i also dislike the fact that my car just isn't a gt4. so far, the locals here have only given compliments and most of them don't even know what the heck i'm driving and give me pointed fingers and confused looks. heck, i get a good laugh everytime it happens.
but exactly what malpaso said, most people won't recognize it since all they'll be looking at is a rare nice looking car (not to be bragging but just to get the point out). only the real enthusiasts (mainly on this site) know exactly what it is.
i couldn't really care less if everybody here thinks it's rice.. because it's my car and i can have it look however i want it to look. though comments are always welcome..
post Sep 4, 2006 - 4:12 PM
FlamingCelica
Joined Apr 16, '06
From Jackson, MS
Looks great man, I wish i could get my little red celi to look like that. frown.gif
~FlamingCelica
94 Red Celica ST
post Sep 4, 2006 - 4:55 PM
trdproven
Joined Aug 2, '05
From Guam
Thats pretty clean looking and great install. Good work, I still remember when you didn't really have much on. Now it totally looks different. You know what would be nice, since you have the sides and rear, is the splitters that I have. Good job!!!
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: November 23rd, 2024 - 4:24 PM
