> Tourque Converter..
post Jun 25, 2003 - 11:26 AM
5sfeTurbo
Joined Apr 14, '03
Slapping a turbo on a 5sfe (Auto) would for sure require a tourque converter. Anyone have any ideas? Also about the Burien kit some in here said the proper intercooler would come from I think it was an early model Supra was this correct? If you read this post and know what you are talking about please reply
post Jun 25, 2003 - 11:48 AM
snadman
From Minnesota, USA
A front mount MKIV Supra (2JZGTE) intercooler will work I think. I also think that the MKIII will work (one of the 7MGTE), you'l need to custom piping done for both though (I recommend an exhaust shop that does mandrel bends). Also, our cars come with a torque converter, so if yours doesn't have one well that sucks lol cuz something's wrong...but I'm guessing you mean aftermarket torque converter and yeah, if you run high boost and you shift with your automatic it would be a good idea to get an upgraded toqrue converter as well as a shift kit. Someone posted something about this and I saved the URL, but since then I have installed a new OS and lost all my favorites so if anyone has that link. It was like 800 bucks or something.
BUT, if you're only going to run 5-7psi like the kit says, don't worry about it.
My recommendation is to go out and buy a car that has an engine meant for a turbo. The 5SFE is not meant to put boost on, although it can be done and very efficiently at that...it wasn't meant to be boosted on. Do a 3sgte swap.
And for those fo you who have seen me everytime say "Do 5sfte if you are short on cash" exnay on that opinion. I no longer feel that you can safely boost this engine to a good horsepower without spending the same money you would on 3sgte. Then, you go and upgrade 3sgte internals and you are talking moogoo HP. Later.
95 Toyota Celica GT
02 WRX --> This is for speed
- Borla Exhaust
- TurboXS BOV
- Custom CAI
02 Civic EX
- Alpine Type S Rear Fills
- Alpine M605 on each Type R
- Phoenix Gold wiring
- Alpine CDA-9855 Head Unit
- Alpine Amp link
post Jun 25, 2003 - 4:01 PM
Guest_Matthew_*
yea good luck finding an aftermarket convertor...
like snadman said just do a 3s-gte swap
you can get a 5th gen gt4 clip from jarcoinc. for about 1500
www.jarcoinc.com
you have to call them...they usually dont reply to emails.
edit: if you do decide to do the 3s-gte swap or the 5sfe turbo thing
call jarco anyway and get a 3s-ge tranny. they are FWD and they will bolt up to your existing tranny mounts...
from what i hear they can handle just as much power as the awd tranny but they are FWD
you can get them from the toyota curren
remember not 3s-gte tranny 3S-GE.
the cost is like 300 bucks or so.
most of them come with LSD so boost all you want
This post has been edited by GT2GT4: Jun 25, 2003 - 4:04 PM
post Jun 25, 2003 - 6:26 PM
bonzaisushi
Joined Oct 3, '02
From bonzaisushi@hotmail.com
www.levelten.com has performance tc's 500 bucks not too bad just gives u a higher stall and more direct shifts
post Jun 25, 2003 - 9:19 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (bonzaisushi @ Jun 25, 2003 - 3:40 PM)
yup
altho a new tqc is not required, a tranny cooler, however, would be a good idea
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Jun 26, 2003 - 12:02 AM
HyperDeathKill
Joined Apr 20, '03
From Chicago
So does anyone HAVE a torque converter installed? I would really like to know if they are pleased with it.
post Jun 26, 2003 - 12:29 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
i know of someone on celica.net with a 5th gen st that has a full level10 tranny with their TC.
but, it is done on other cars with good results, the car gets much better power transfer and faster acceloration
post Jun 26, 2003 - 11:55 AM
5sfeTurbo
Joined Apr 14, '03
Is all this usless with an automatic? And please dont say swap the tranny cause I know the car just dosent run correctly after that.
post Jun 26, 2003 - 1:00 PM
snadman
From Minnesota, USA
LOL. The car does too run correctly. You know how many people swap out trannies in cars? What about people putting in a Turbo 350 tranny into something that wasn't meant for it all, or a total custom rod. Do those run correctly? I think so. It bolts right up too, no hassles. If you're going to swap the tranny though, why not go the whole 9 yards and switch to manual? If not, you got a few choices:
1) You could leave it stock and just add a nice tranny cooler, probably a transmission temperature guage...and you should be alright.
2) You could have the existing tranny rebuilt to higher gear ratios. This will allow you to have basically a brand new tranny, so obviously there will be substantially less power loss and you will have esentially a 4 speed semi-manual tranny if done the right way. If you send ti to the right people, which you will have to find out for yourself who those are in your area, then they can rebuild it so it feels like when going from Low (1st) to 2nd to Drive (3rd) it will feel like you're controlling the shifting. From there, if you have pedal to metal (racing situation...hopefully on the track my friend) it won't shift into the final drive gear until you hit close to redline.
3) Number 2, plus a new/rebuilt torque converter. Not necessary, but may be nice to get rid of 90% of your power loss problems if partnered with a rebuilt tranny or swapped tranny.
4) Swap in a 3s-ge transmission. This would be a cool idea. I haven't seen this done yet, because most times people swapping a 3sgte into their 5th or 6th gen Celi's will use their existing transmission or convert to AWD and use the 3sgte.
It's all up to you man, there's so many choices...so don't limit yourself by saying something can't be done. Swapping in a 3s-ge transmission will probably cost just as much as rebuilding your existing one. And a torque converter, it's only advantage is less power loss.
95 Toyota Celica GT
- Borla Exhaust
- TurboXS BOV
- Custom CAI
02 Civic EX
- Alpine Amp link
post Jun 26, 2003 - 1:14 PM
HyperDeathKill
Joined Apr 20, '03
From Chicago
I do believe torque converters ONLY work with automatic transmissions. I could be wrong though.
post Jun 26, 2003 - 1:47 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (HyperDeathKill @ Jun 26, 2003 - 10:28 AM)
yes they are what make auto tranny's possible. they only work with auto tranny's
post Jun 26, 2003 - 5:55 PM
bonzaisushi
Joined Oct 3, '02
the only thing the converter will do is flow the tranny fluid better... it will suck for daily driving, because the stall is soo high well 3400 i believe wich is way better than are 2200 stall... and theres no point on getting gears done on are auto... for 1 that would be the price of a manny swap almost.. and are auto gears arnt short, it will sit and not shift till redline in all the gears with the foot to the floor... wouldnt it bee better if we all had mannys confused.gif
Lo-Fi Version Time is now: December 3rd, 2024 - 6:19 PM
