> Removing Spoiler, wtf....not workin
post Sep 22, 2006 - 11:40 AM
nader
Joined Oct 11, '05
From Ajax, Ontario
so im trying to install my blocks and im having trouble removing the spoiler, i removed all of the bolts and it still doesnt come off, im assuming theres some type of adhesive holding it to the car still? i pulled and pulled but nothing..anywone have any advice on what to do?
post Sep 22, 2006 - 11:52 AM
Starcraftjunkie
Joined Nov 21, '05
From Wpg, MB. Canada
go search for Asian-Advanced's how-to when he put in his blocks
post Sep 22, 2006 - 12:00 PM
celicaST
Joined Jun 23, '05
when i took mine off for the first time, i used an old credit card and worked around the edges picking and cutting at the adhesive. do that a while, and then just give it a nice pull. afterwards your going to need some goof-off to get off the remaining adhesive.
post Sep 22, 2006 - 12:11 PM
My2Celi
Joined Dec 9, '05
From Bedford, TX
I just took mine off yesterday. It has 2 bolts on both side and one in the middle. I notice there is double sided tape once i took it off. you just gotta find something like a knife to cut through the adhesive like celicast did.
IPB Image <--- I miss :'' (
post Sep 22, 2006 - 12:35 PM
nader
Joined Oct 11, '05
From Ajax, Ontario
QUOTE(Starcraftjunkie @ Sep 22, 2006 - 11:52 AM) [snapback]482634[/snapback]
well thats what i was following but the problem was that in the how to it said tha they should easily come off ...they didnt><
ok thanks for the help ill go ttry that now
post Sep 22, 2006 - 12:55 PM
My2Celi
Joined Dec 9, '05
From Bedford, TX
they dont come off easily at all. i took off 2 spoiler off of 2 gt's and both wasnt easy to take off. its just the adhesive that is difficult to work with.
post Sep 22, 2006 - 10:30 PM
6strngs
Joined May 12, '06
From Wilmington, NC
I took the spoiler off my hatch a couple days ago. it was real easy. I just opened the hatch, removed the two bolts on each side, took off the big plastic piece on the interior of the trunk to remove the other bolt on each side and it came right off! a little dirty underneath, but no there was no adhesive stuff...
post Sep 22, 2006 - 11:56 PM
azian_advanced
Joined Apr 18, '05
From Calgary
yeah.. i didn't have any adhesive on mine either... hmmmm
post Sep 23, 2006 - 1:11 AM
DSRT-FX
Joined Sep 13, '04
From Sydney/Australia
im guessing the oem 2-post spoiler came without adhesive and the oem 3-post spoiler came with adhesive.
all you need to do is use goo-remover and use a fine fishing line to slowy slice it off... try not using sharp tools since you'll just be damaging the boot -R
ROM-23L 67 + 76 = 143
"I wasn't pursuing Sephiroth, I was being summoned by him." - Cloud Strife
post Sep 23, 2006 - 1:47 AM
nader
Joined Oct 11, '05
From Ajax, Ontario
darn i didnt think it would be so tough to get it off, im trying everything here the damn thing will not budge
post Apr 30, 2013 - 7:52 PM
Lane
Joined Oct 17, '10
From Jax. Fl.
QUOTE (nader @ Sep 23, 2006 - 2:47 AM) *
Nader did it ever come off? I'm having the same problem won't come off
post May 1, 2013 - 12:45 AM
smkr3w
Joined Nov 29, '10
From Lake Havasu City, AZ
QUOTE (Lane @ Apr 30, 2013 - 5:52 PM) *
Holy 7 year necrobump Batman!
The spoiler is held down with 2-3 bolts pert side. Can be founder under the trunk plastics. Also super strong double sided foam tape. after you are certain the bolts are all out and there is just the tape- pick a side and give an easy but FIRM tug. should come up after a bit. after one side is off carefully raise the loose side to aid in breaking the bond , CAREFUL not to break the spoiler!
Lo-Fi Version Time is now: February 18th, 2025 - 7:16 AM
