my sidemarker not working!!, my sidemarker not working!! |
Sep 27, 2006 - 11:15 PM |
Enthusiast Joined Sep 27, '06 Currently Offline Reputation: 0 (0%) |
one of my side marker light bulb is burnt out, but the other side light bulb is still good but they both dont work HELP!!
Sep 28, 2006 - 12:36 AM |
Just in case, get another bulb. Also check your fuses. These are the first things to check before you panic.
Sep 28, 2006 - 2:36 PM |
Enthusiast Joined Jul 20, '06 From St. Thomas, Virgin Islands Currently Offline Reputation: 0 (0%) |
umm...don't mean to thread-jack...but I have a similar problem with a rear signal, changed the bulbs and checked the fuses, everything's fine. It's just the one signal that's not working, but what else can be done? Change the metal piece that the bulb goes into?
-------------------- "I bet you drive a standard." "You could make some money off that bet." :D |
Sep 28, 2006 - 3:16 PM |
Enthusiast Joined Aug 21, '06 From washington Currently Offline Reputation: 4 (100%) |
i have the same prop wit my driver side sidemarker but if i hit it a few times it comes back on. i think its either somthing is loose in the housing itself or that it could be the ground wire. im goin to reground my sidemarker soon.. hell i'll do it know and see if thats the prop wit mine.
Sep 28, 2006 - 3:19 PM |
this is where a test light comes in handy...
it only costs about $6.. QUOTE i have the same prop wit my driver side sidemarker but if i hit it a few times it comes back on. i think its either somthing is loose in the housing itself or that it could be the ground wire. im goin to reground my sidemarker soon.. hell i'll do it know and see if thats the prop wit mine. in your case, you need a new bulb. it seems the filament inside has already broken but is still hanging and occasionally goes on and off. i've had that problem a bunch of times. -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Sep 28, 2006 - 5:07 PM |
One thing possible as well is, the harness' contact is not tight enough for the bulb or both contacts meaning bulb and harness are not touching or is not aligned with each other. Sometimes can be corrected by bending the contacts inside the harness to reposition them.
Sep 28, 2006 - 5:36 PM |
QUOTE(azian_advanced @ Sep 28, 2006 - 1:19 PM) [snapback]484885[/snapback] this is where a test light comes in handy... it only costs about $6.. QUOTE i have the same prop wit my driver side sidemarker but if i hit it a few times it comes back on. i think its either somthing is loose in the housing itself or that it could be the ground wire. im goin to reground my sidemarker soon.. hell i'll do it know and see if thats the prop wit mine. in your case, you need a new bulb. it seems the filament inside has already broken but is still hanging and occasionally goes on and off. i've had that problem a bunch of times. ive changed the bulb a few times and that wasnt the case. but i fixed it anyway. my harness was old and was falling apart. -------------------- |
Sep 28, 2006 - 6:18 PM |
Enthusiast Joined Apr 19, '06 From Long Island, NY Currently Offline Reputation: 13 (100%) |
What I would do if I was you:
Use a multimeter, and set it to test for voltage, hold the 2 pins inside the plug for the 194 side marker bulb. If you see 12 volts, then you know that all your wiring and fuses are fine, and you have a dead bulb. If you see 0 volts, or less than 11 volts, then you have a problem in your wiring, or the plug itself. -------------------- '92 Grey Mitsubishi 3000GT SL - Sold
'96 Black Celica ST 25th Anniversary - Sold '99 Black Mitsubishi 3000GT VR-4 - Sold '04 E250 Work Van - Going soon '08 Grey Dodge Charger Work Car - Ordered |
Sep 29, 2006 - 7:45 PM |
okay, I fixed mine, the harness had a LOT of corrosion so the wires that supplied power to it weren't really toucing metal. I scraped off some of the corrosion and pressed the wires against the metal and voila! (Now I have a bunch of extra signal bulbs...grrr...)
Lo-Fi Version | Time is now: November 28th, 2024 - 3:50 PM |
