> HIGH Idle, need help!
post Sep 28, 2006 - 9:02 PM
nate95
Joined May 5, '05
From mattoon, IL
hey guys, for some reason my car has been Idling higher than normal, mainly when its cold, like when i just start it up it will be almost up to 2,000RPM with the clutch all the way in, after it warms up its still high but not as much, it'll stay around 1,000 or just barely under that,, why is it doing this?? i just had the oil changed about 200miles ago.
post Sep 28, 2006 - 9:08 PM
Celicaguy13
Joined Sep 9, '05
From Modesto, CA
Who changed your oil? A vacuum line may have accidentally been disconnected. Check all the little rubber lines coming out of the intake manifold, and ensure they are all connected to something. That's a good start.
post Sep 28, 2006 - 9:10 PM
nate95
Joined May 5, '05
From mattoon, IL
Midas changed the oil, they'v always done a good job... ok i'll check the lines, i just looked under the hood alittle bit ago, im sure there all connected
post Sep 28, 2006 - 9:20 PM
Celicaguy13
Joined Sep 9, '05
From Modesto, CA
Yeah but lines could also just come loose over time/age/bumpy roads etc. Be sure to check both ends of the lines, not just the manifold ends.
post Sep 28, 2006 - 9:29 PM
nate95
Joined May 5, '05
From mattoon, IL
ok, thanks. any other suggestions from anyone else while im under the hood??
post Sep 29, 2006 - 12:44 PM
nate95
Joined May 5, '05
From mattoon, IL
hey i checked the vac lines and there jsut fine??
post Sep 29, 2006 - 12:50 PM
if you're coming to the oct 22nd i can take a look at it, i know my way around the 7A-fe.
post Sep 29, 2006 - 1:07 PM
check for vacuum leaks.
post Sep 29, 2006 - 1:49 PM
nate95
Joined May 5, '05
From mattoon, IL
i will most likely be there bitter,, thanks!
post Sep 29, 2006 - 5:57 PM
Celicaguy13
Joined Sep 9, '05
From Modesto, CA
Also if you have access to a timing light, check to see if the timing is advanced. Check both with the timing connector connected and disconnected.
post Sep 30, 2006 - 11:23 AM
Alex-UKSC
Joined Jul 23, '06
From Chester - UK
The idle valve maybe sticking ?
My Celica Is Now For Sale
post Sep 30, 2006 - 12:51 PM
nate95
Joined May 5, '05
From mattoon, IL
wheres the idle valve at? how do i check it?
post Sep 30, 2006 - 5:26 PM
XS4lv1Truch0x
Joined Dec 9, '05
From Long Beach
car is up 2000 rpm cause of a possible vaccum leak.
check out the throttle body, check your hoses too that they arent cracked. the rubber hoses get hard over time and they start cracking if you mess with them.
Is this good enuff 4 ya? :D
Lo-Fi Version Time is now: February 25th, 2025 - 5:16 AM
